worked a treat nice one
Starview 5 - firmware
Help
Help Please!!!!!!
Hi i have a tiny little problem would be grateful if you could help in anyway thanks
1) I have a box usb2 ive have done an auto scan and tried to use 1570 to turn onthe EMU
but it wont let me into the 1570 menu is there any other way to turn EMU on ???
2) I also have the Box Super Usb, wich i was updating with the new Binfile it started updating but i had a power cut
now the box has on the front 8882 but does nothing what can i do?? in there a way to use the null modem cable is there a GTRom for this box, pease help if you can.
Thanks yours DesertratComment
u have bricked it then if u shut it down as the firmware was installing , use theHelp Please!!!!!!
search m8 this has been posted a few timesLast edited by smirnoff_rules; 15 October, 2009, 20:53.any information provided is for educational/experimental purposes only.Comment
Hi thanks for the reply m8 how bout q1) 1570 menu anyother way round that m8 or do i hv to return this box as i hv just bought it 3 days ago.
thanks Desertrat
starview 5 working
hi guys not sure if this will help u,but wen i install the new firmware TheboxSuperUSB2_v2.03.20090923.BIN did everythink right on how to install the firmware after i did a scan it rebooted, my tv box just had standard channels so i went to menu pressed 1570 went to nagravision witch lets u change the codes. and i noticed my provider was wrong for my area and codes where, so i changed them to the latest codes for my area and now it works great,make sure u turn the keycode to on? to get the latest codes for ur area just download the bigmaq toolbar it will give u the latest codes and firmware?hope this helps u guys
if you have updated firmware no need to enter codes,press set default key and emu or keycode to on and exit out to a sly channel it should update.hi guys not sure if this will help u,but wen i install the new firmware TheboxSuperUSB2_v2.03.20090923.BIN did everythink right on how to install the firmware after i did a scan it rebooted, my tv box just had standard channels so i went to menu pressed 1570 went to nagravision witch lets u change the codes. and i noticed my provider was wrong for my area and codes where, so i changed them to the latest codes for my area and now it works great,make sure u turn the keycode to on? to get the latest codes for ur area just download the bigmaq toolbar it will give u the latest codes and firmware?hope this helps u guys
, but that firmware doesnt hv eg listings thankyou again.
