Starview 5 - firmware
  • belker
    My Starview 5 was working fine until today, its on version 2.03 firmware and set to keycode on. Most channels say no signal, some say updating.
    Any suggestions? TIA
    • DESSERTDOG
      • 493
      #452
      do a factory reset rescan then turn keycode to on or search the forum this question has been asked many many times
      If i have helped you please dont post Thanks just use the Thanks button
      • lostgirl
        • Feb 2010
        • 28
        #453
        hiya all...im new to this jargon so please explain in the easiest format for me.... if you can help... i have the box super usb. i have had for abt 8 months.im on virgin media.in the east midlands.the box was working last nite.and this morning all we getting is the basic 1-5 channels. have done everything to get channels back. >menu>1570> network key>on>>automatic scan> full signal is there. I kinda heard that there mite be a signal block so that people can no longer use these boxes. is there anybody who can help or advise please? thank you.
          answered in your other post m8. keep to the same post as it gets confusing to people trying to help you..
          • patflah
            • Feb 2010
            looking for starview5 secret menu
            need help to find starview5 usb secret menu
            can anyone help
            • theted1
              • 11
              #456
              can anyone help
              Digital Kaos - Downloads - Plain Text File SV5 Tut
              hope this helps !!
              • s80051
                • Feb 2010
                ne1 gt ne new codes for starview 5
                • DESSERTDOG
                  • 493
                  #458
                  There are NO new codes if you do a bit of reading you can cure your problem m8 and a few manners go a long way
                  • martinj1207
                    • Feb 2010
                    Have Starview 5, been working fine for months but some channels have stopped working but not all. Any ideas as to why?
                    • DESSERTDOG
                      • 493
                      #460
                      Simple's read post 468
                      • mekka
                        • Feb 2010
                        Starview 5
                        Just purchased and the download works a treat!!!
                        • bigdonkey
                          #462
                          Hi, a little while since i been on these Forums, is the TheBoxSuperUSB2_v2.03.20090923.bin still the lastest firmware for the SV5?
                          I do have every possible channel but I thought there might be a problem with this firmware because i seem to have several versions of each channel stored, only one or two versions of each channel work, many dont have complete programme listings on the EPG and some versions dont work altogether therefore if i decide to delete the several stored versions and only leave 1 copy of each channel i'm in danager of leaving one of the versions that doesn't work. Is there anyway around this so that one the version of each channel appears in the EPG? Does anyone else have this problem? Many Thanks in advance for your help!
                          • bigdonkey
                            #463
                            ....this time in colour!!! Hi, a little while since i been on these Forums, is the TheBoxSuperUSB2_v2.03.20090923.bin still the lastest firmware for the SV5?
                            • dpfaulkn
                              • Feb 2010
                              Starview 5
                              Hello,
                              I am new to this site. The other day my Starview 5 box lost all the cable channels. I think I need the new updated firmware, so my friend tells me. Can anyone let me know if this is the case?
                              dpfaulkn
                              • DESSERTDOG
                                • 493
                                #465
                                Originally posted by dpfaulkn
                                Hello,
                                dpfaulkn
                                When you find it let us know or post it on here m8 as far as i know 2.03 is the latest
