Starview HD Combo LAN & NON LAN STBs
  • jasbo7
    • 1432
    #151
    Originally posted by bill4676
    looking for help on how to make a server for card sharing so i can send and recive cline
    • xdoktor
      • 11
      #152
      Originally posted by cactikid
      i thought you could use the ordinary usb dongles formatted to fat32,"usb1 or usb2 , pref usb2 , fat32 , 64mb to 32 gig"
      i thought the reference was for 'Wifi' or 'Lan' dongles for us 'non lan box' owners :-)
      regards
      Dok
      • cactikid
        • 12017
        #153
        regards
        Dok
        too many threads to follow,thought you meant for flashing.
        • xdoktor
          • 11
          #154
          haha cactikid!
          you need a rest :-)
          peace
          dok
          • tabtab86
            • Feb 2010
            #155
            update?
            Hi all,
            Noticed a few problems after 12am this morning. Cant view channels any more. Box reports 'no signal'. Have done rescan but finds nothing.
            Bought the box yesterday afternoon, all set up and worked spot on after updating to latest Grooverider firmware.
            Is it just coicidence that i've lost everything on 1st March or does firmware need updating at the start of the month? I know some details about these units but i'm by no means a flyer with how often they need flashing/updating etc.
            If anybody could let me know where I stand that'd be great.
            Cheers
            • tabtab86
              • Feb 2010
              #156
              update
              thought i'd mention I have a Starview Combo HD+ (with LAN)
              • cactikid
                • 12017
                #157
                with a lot of channels moving people have to factory default to erase the cable channels and auto scan your provider and is it emu or keycode to on,if you have moved into a nagra3 area you will lose all cable channels.
                • banchod
                  any ideas why my starview HD doesnt disply Sky movies channel, but sky sports ok + others?, i have tried factory reset and scanned but will not decode Sky movies stuff?
                  • Babyface786
                    • 27
                    #159
                    contact your server admins.
                    http://gifts.freebiejeebies.co.uk
                    • bils779
                      • Mar 2010
                      • 7
                      #160
                      set up of combi
                      hello guys i am new to this.............. been reading the threads on setting up the sat side of the combi...am i right in thinking that this has a cccam already set up..if so how do u get it to work...the more i read .... the more i dont understand..
                      i have the cable side working fine on latest firmware and groverider..but cant get haed around the network bit
                      • pongo snodgrass
                        • 178
                        #161
                        here read this mate...i coudnt get the CCcam.cgf to load via usb, had to use the remote, looks like it varies from box to box...
                        Personally, i think this box is terrible regarding the sat side of it. There is somekind of bug in the either the software or the hardware. Ive tried every single fw that has come ou for this box and none have fixed the problems. I loose connection to my server after about an hour or so, i then have to reeboot the box. glitching and freezing is common on this box, ive tried about 6 or 7 different trial servers, get the same problem. I thought it might be heat related, so i removed the top cover of the box to allow air to circulate, still get the same problems. I then bought a large laptop cooler fan , placed it underneath the box, still the same. the only thing i can say good about this box is it is small, not very expensive, although ?200 is still a lot...let us know how you get on mate.
                        "For the satellite side to go on network you need to go to Accessory and press 8989 on your remote,this will open up the hidden menu.. then go to the right side on the menu to network.
                        Press OK on network then go to Type then you will see 4 more sections in the menu, go to Server setup and press OK You will see 10 different Servers
                        in there,
                        Go to off 1 and press ok, in the menu it will say off if you highlight OFF and go to the right on the remote you can pick CCCAM or NEWCAMD in the menu.
                        This is where you can setup your server needs here.
                        If you have a Config file (CCCAM or NEWCAMD) made up , put it on a Memory Stick then go to USB in Accssory and press OK.
                        At the bottom it will say Config highlighted by a Red button, if you press the Red button on the Remote it will give you 3 chorses,
                        pick Auto Detect then it will start to read your memory stick if you got your Config file on your stick it will then load your config file in here.
                        Now go back to Network and press OK then Server Setup you will then see all you Config details have now been loaded in your"
                        • Flapper
                          • Feb 2010
                          #162
                          Hi I have a HD combo+ I have got the cable channels working but how do you get the sat part decoded I have got the freeview channels can anyone help .thanks
                          • tornado
                            • Oct 2008
                            • 218
                            #163
                            hdcombo
                            is there any new software comming out for this box like to fix all the trouble its got
                            • wertyu
                              • Mar 2010
                              guys any help please have been reading through this, i have a lan box have put the correct software on a done the factory reset, have the correct symbol rate picked but when i do a channel search nothing found. Any ideas please?? wertyu
                              • binusona
                                • Jun 2009
                                • 4
                                #165
                                hai i installed firmware but 8989 notworking
