Starview HD Combo LAN & NON LAN STBs
  • confusious
    #226
    Originally posted by jahnuhdead
    YEP IT DOES WORK .... I HAVE MANAGED TO MAKE THE SATELLITE SIDE WORK WITH A C-LINE AND ALL IS WELL, I WILL POST A STEP BY STEP GUIDE LATER. ITS ALL GOOD NEWS.
    I have been trying for days to figure this out, interested to know what you did????
    • jahnuhdead
      • Mar 2009
      • 5
      #227
      RIGHT GUYS PLEASE FF THIS CAREFULLY OR NOTHING WORKS.
      HERE GOES NOTHING> THIS IS ONLY FOR LAN COMBO.
      FIRST SOFTWARES NEEDED ARE (0128.UAD,1214.UA AND 0212.UA). ALL THESE FILES CAN BE FOUND ON THE EARLIER PAGES, JUST GO SHOPING.
      NOW YOU NEED TO FIRST INSTALL 0128.UAD (SW+ALL DATA UPDATE). THEN NEXT BY INSTALLING STRAIGHT AWAY 1214.UA . REMEMBER NO FACTORY RESET OR POWER OFF THEN ON.
      LAST OF ALL DO 0212.UA . THIS IS THE LATEST SOFTWARE.(SW+ALL DATA UPDATE).
      THEN EXIT MENU AND YOU WILL SEE THERE WILL BE SOME CHANNELS ALREADY,DO A FACTORY RESET TO DELETE THEM.
      NOW DO ALL YOUR SCANING FOR CHANNELS.
      THEN ACCESSORY 8989 FOR CABLE, IT WILL BE AUTO ON. SWITCH POWER OFF FOR 5SEC. THEN ON AGAIN.
      NOW GO TO NETWORK PUT TYPE ON,
      IP SETUP TO AUTO,
      SERVER SETUP IS HERE YOU ENTER YOUR C-LINE OR NEWCAMD THEN APPLY.EXIT TO SERVER THEN WAIT FOR 2MIN FOR BOX TO TALK TO NETWORK.
      YOU SHOULD SEE AT THE END SAYING CONNECT.
      BUT REMEMBER THAT IT SHOULD BE STABLE.
      IF YES EXIT EVERYTHING TO LIVE TV AND ENJOY......
      AVAILABLE FOR MORE HELP. IM OUT.
      • cactikid
        • 12017
        #228
        please post in lower case =no caps as you are shouting.
        • tornado
          • Oct 2008
          • 218
          #229
          shame the box is crap
          • pongo snodgrass
            • 178
            #230
            so true.this box is ...i wanna tm800hd but ive spent my money on this sv hd box...i wish i had waited..
            • satsmo
              • 6397
              #231
              Bin files for UK & Ireland N3 areas updated on page 1. For LAN Combos only. http://www.digital-kaos.co.uk/forums...cs-v1-00-1228/
              • charlie_scotts
                • May 2010
                Hi, I have bought a HD combo box. I am VERY useless when it comes to these sorts of things but I am trying to help my parents. So some basic questions and I am very grateful for whoever can help me.
                Is the free server gone live yet?
                How do i get on? Do I just download Starview Combo LAN UK CS Firmware V1.00 and install it, then enter the right code for virg and then do a cable scan?
                Thanks!
                • alex123
                  • 832
                  #233
                  not tried it yet but i think u should install firmware,scan,then select uk
                  • lordmac
                    • May 2010
                    new here have the starview box not sure if its the clone box works fine when i load the codes how long will this type last, and what is the best cable box for me to be looking at getting and will the new box help when they change over to hd
                    • boomer39
                      • 2818
                      #235
                      heard of nagra3 yet?????????????????
                      YNWA..
                      • jahnuhdead
                        • Mar 2009
                        • 5
                        #236
                        well i tried to help so no one should be mad.. for i know it works if u know how and i am enjoying it now.
                        life is sweet.
                        • satsmo
                          • 6397
                          #237
                          No one is mad, it is just good forum netiquette not to post in caps. What you posted was contained in the readme of the latest particular bin file you used in downloads.
                          • jahnuhdead
                            • Mar 2009
                            • 5
                            #238
                            what i am trying to get across here is the format in which we download and apply it to the box. in a haiste the box wont work but with carefully planned step by step way, it will work.
                            • satsmo
                              • 6397
                              #239
                              Don't rush and follow instructions is probably a given.
                              • sunny_g
                                • 12
                                #240
                                Bin files for UK & Ireland N3 areas updated on page 1. For LAN Combos only. Digital Kaos - Downloads - Starview Combo LAN Ireland CS V1.00
                                hi is this to use with starview hd combo + lan? if so just follow the setup guide and plug lan cable in and i should be ok to view? what channels would it be showing?
