Notts Area all channnels off at 1.30am Wed
  • mann
    • Feb 2010
    • 4
    #61
    Eurovox help please anyone
    Originally posted by mick1888
    hi every thing working fine, just rescan and you will everything back,
    Pls i got a new Eurovox, after scanning all channels are scrambled except the free channels. Pls what should i do to unscramble all the channels?
    • shank
      • 22
      #62
      Chaps and Chapesses, please call me an idiot.
      Having just spent an hour following instructions, factory reset, keycode etc, much headscratching, shouting and swearing, i suddenly realized i hadn't reinstalled 1.12 D'OH. All channels back now, cheers!
      • badapple
        • 2041
        #63
        Hi m8, First you will have to flash the box with the latest firmware and then scan for channels. Tell us what model of Eurovox you have and we can give you the correct firmware.
        And tell us in which part of the county you are in as some places have gone to N3 and all thes boxes are dead.
        SLOWLY, OUR FREEDOM IS BEING ERASED.
        SOON, WE WILL JUST BE A NUMBER.
        IF WE DON'T FOLLOW, WE WILL BE ERASED.
        • shank
          • 22
          #64
          It gets better, after flicking through everything, i've got more channels than i had before! Could never get vermin1 before.
          • rickyuk44
            • Feb 2010
            • 4
            #65
            hiya guys i have a starview 3 and its gone tits up so has a few of my friends who also have the same box notts area 10 feb 2010 anyone know how to fix this do i need to flash with new firmware or can i just change the code ?? hope someone can help
            • gsxr
              • 14
              #66
              Originally posted by RiPPeR
              If you go to menu then channel edit, then look there there should be a FX on chan 511 and a SS1 on 511. Then delete the FX then save, I also had to update to 1,12.
              I have got the channel sorter on my laptop so i deleted the C5 and changed the FX to channel 161 as it was nowhere else. Thanks anyway mate
              • mark36
                • 166
                #67
                menu
                factory reset
                set provider(notts 6887)
                fresh install
                exit out to tv
                then menu
                key in 1570
                will bring up the nagra page
                press default key
                turn EMU on
                exit out
                go to sky sp1 and let it update
                should all be good
                • mej2904
                  • Jun 2009
                  • 11
                  #68
                  Hi Guys,
                  Followed the advice from RIPPER and all is well again...
                  " I did a Factory Reset, then in menu press 1570 turn 'ON' the key. Do a re scan, then you should have all your channels back "
                  Many Thanks
                  UPDATE.. I deleted FX .channel, let it update to 511 sp1
                  • gav moody
                    • Feb 2010
                    Lost some chanells in Derby Area as well on my SV4,(SSP1,3&4 ETC). Downloaded new firmware V12 and all is ok.
                    Thanks to all for help!!
                    • heno1969
                      • 17
                      #70
                      [QUOTE=RiPPeR;451091]Nice Avatar
                      Thank you kind sir.....Only the best team for me!!
                      • mickace1
                        • Jun 2009
                        starview 4
                        hi i too am having the same problem. done factory reset + 1570 stuff and rescanned but channels not updating. grr. do i need firmware update???
                        • gurps1234
                          • Feb 2010
                          Originally posted by maca58
                          scan each box from the main feed. no splitters..
                          Good point, thanks..Most of my channels now work...not the asian channels though :-( B4U/zee..etc etc...any ideas? :-)
                          • unicorn999
                            • 19
                            #73
                            hi lost everything tryed rescan comes up no signal and only finds 28 channels tryed putting in superusb firmware again secret menu and scan still no signal and only finding 28 channels plugged ntl box back in and that working fine have read do a factory reset how do you do this or does this just mean start from scratch as if you just had box or is there a procedure i have to do any help aprrieciated
                            • d3g5y
                              #74
                              had the same problem i had to go into menu and edit channels as ther was fx on the same channel as s/sports so i deleted fx and was able to gain access to s/sports
                              • kotechs1
                                • 4
                                #75
                                Does any1 know how to get back out of the
                                "downloading plz wait screen"
                                I had the older version 1.07 after reading posts thought 1.12 would solve problem and started the process
                                been stuck on that screen for past hour
                                Help plz..
