Hi Techies - hoping you can help. Just purchased the above box to replace my Starview 3 and i cannot access the "secret" menu. Can you tell me where i do this from in this new menu or do i not have the correct firmware? Thanks
Starview 5 USB II
you could have done a research before buying any cable boxDreamBox 500HD NewEnigma2 -
Thanks for the info BlueBox. I had heard about this new software coming in from Virgin but would hope for a few months viewing yet! - perhaps not!!
My location is Great Barr, NW Birmingham if anybody has some acurate info on this security stuff.
Model of my box is a C531 / S/W Version 2.04.MP / Boot Version - B-21 - not sure if this helps!
Tried code 1570 from the menu but no keycode menu has come up.
Any further help would be much appreciated
I'm in B-ham aswell, firstly although the cards have not been sent out yet they are imminent!! I would say you've probably got approx 4 weeks but don't quote me on this, nobody but vm know for sure. The firmware I am running & according to many on here is the most stable is v2.03. If you d/l this then install onto your sv all should be ok, if not come back & post your problem, someone will be able to help.Thanks for the info BlueBox. I had heard about this new software coming in from Virgin but would hope for a few months viewing yet! - perhaps not!!
Thanks Larryoke - Appreciate the support. Not really good with these tech things so if you assist me with a step by step guide on how i find this firmware to get it on a memory stick and then want i do after that then that would be great.I'm in B-ham aswell, firstly although the cards have not been sent out yet they are imminent!! I would say you've probably got approx 4 weeks but don't quote me on this, nobody but vm know for sure. The firmware I am running & according to many on here is the most stable is v2.03. If you d/l this then install onto your sv all should be ok, if not come back & post your problem, someone will be able to help.Comment
You don't need to be a "techie" to flash a sv5, if you download this 1st
SV5 tut
Have a good read, it is an easy to follow guide, this is the firmware you need
TheboxSuperUSB2_v2.03.20090923.BIN
Please remember to power off the sv before inserting/taking out the usb.
the firmware is a bin file just drag & drop onto a formatted usb stick.
None of this work is mine, please say thanks to the authors.Comment
Thanks again LarryokeYou don't need to be a "techie" to flash a sv5, if you download this 1st
SV5 tut
you haven't seen me with the tech stuff
Downloaded the firmware - thanks to the authors and will try it out tonight with the instrcutions. Cheers
Help!!!
Loaded the firmware onto a usb stick and tried on the SV box - (getting the jargon now
) switched off box placed usb in, then switched on box - 4 lines come up but then nothing? From the menu i located the USB pressd ok and the bin file come up on the TV screen and asked me to format to which i pressed yes to confirm
File disappeared from the screen and usb so i thought uploaded? From the menu screen i pressed 1570 but no secret menu appeared??
Switched off the box and unplugged the usb. Switched on the box and still only channels 1 -5 came up but i did notice that this time 8882 came up on th ebox before it went to BBC1 - does this mean anything.
As always forum people any help would be greatly appreciated. SteveComment
Did u read the TuT ? and follow it ?If i have helped you please dont post Thanks just use the Thanks buttonComment
As DESSERTDOG says, if you read & follow the tut it's easy enough, format the usb then load the bin file onto that, once inserted into sv choose menu >option usb & from there it's simple, language > auto installation (on your provider TW I assume) > once complete press menu 1570 (on remote) turn keycode to on > ok on set default > exit to a $ channel & wait for update > sit back and enjoy free tv for a week or two.Comment
