starview 5 secret menu question
  • tomuk30
    • Aug 2009
    • 36
    Hi,all I cant access the secret menu ,do I have to update firmware from new ,in order to access this ? im using 1570 after pressing menu after tuning
  • tomuk30
    • Aug 2009
    • 36
    info off the box if it helps
    model id c531
    sw version 2.06 mp
    boot version b.2.02.091023
    date feb 02 2010
    • mark8393
      • 2305
      model id c531
      sw version 2.06 mp
      date feb 02 2010
      you should be able to get to menu, but load 2.03 as its more stable, and it may get you into menu.
      • tomuk30
        • Aug 2009
        • 36
        its new and cant update ,or I cant return it ,I think its faulty as ive not had this problem
        • mark8393
          • 2305
          why cant you load software, doubt anyone will accept returns with nag 3 coming soon, not sure what you are saying, can you make yourself clear.
          • tomuk30
            • Aug 2009
            • 36
            basically do I have to load the software (or what you want to call it ) to get to the menu after pressing 1570, as I cant access the menu nothing happens what so ever
            • boomer39
              • 2818
              not 100% but i think 2.06 is fta software. so you will not get to do 1570. you need to load 2.03 on your box...
              YNWA..
              • smoggy
                • Apr 2009
                • 12809
                you can get the v2.03 firmware here Digital Kaos - Downloads - TheboxSuperUSB2_v2.03.20090923.BIN
                and the instructions on how to load it here Digital Kaos - Downloads - SV5 tut
                • tomuk30
                  • Aug 2009
                  • 36
                  thanks for the answer ,that explains why
                  • tomuk30
                    • Aug 2009
                    • 36
                    can you revert back to original software?
                    • cactikid
                      • 12017
                      only if some one has the original.
                      • tomuk30
                        • Aug 2009
                        • 36
                        any suggestions were to look ?
                        • dannyuk89
                          • Mar 2010
                          • 225
                          go to menu and press 1570 a box will appear turn keycode to on exit then scan chanels
                          • tomuk30
                            • Aug 2009
                            • 36
                            i need to update firmware to use secret menu .i now want to know if i can revert back to the original firware of 2.06mp
                            • cactikid
                              • 12017
                              no idea have looked around and have not seen it posted
