sv7 is same like sv6 no difference just they make it little better also got lan port.
starview 7
Did you know I was looking for that link all day today well could you?
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
Its out on Wednesday mates fingers crossed
the network is via the RS-232 Converter. It comes with the box. The box works are same as the starview 6 as I have got a Starview 7 Box. Setup is the same as starview 6 but you need the Carling Firmware for the Starview 7 box. Using the Starview 6 firmware on the starview 7 box will brick the box be warnedLast edited by m1nz; 24 September, 2010, 21:26.Comment
its the stuff we think we know that stops us all from learningComment
Starview 7 now released, the box has no lan port but is connected via a dongle
installing sw is same as sv6, there is not much difference between the two models just the network port has been made external ..
The unit will work on sv6 or 7 software so you wont blow it up by loading wrong files and support will continue for all models 6, 7, and combo units.. (words from wizzard himself)
Firmware here
"(words from wizzard himself)"
I would'nt beleave anything Wizard tells you m8.
Ask Wizard about the support they provided for the Combo non Lan boxes!
Peeps are still waiting on the network Lan dongles for them receivers.SLOWLY, OUR FREEDOM IS BEING ERASED.
SOON, WE WILL JUST BE A NUMBER.
IF WE DON'T FOLLOW, WE WILL BE ERASED.Comment
Still awaiting confrimation from a mate re information on this but I personally cannot find any set up info or firmware, just mentions of Carling 1.02, which to be honest I haven't a clue about.Comment
If you read around you will find all the answers you require. All answers are on the forum
