Just because I am a Volkswagen user, relatives gift to me the chocolate rabbit also named Lindt Bogs Bunny.
Looks cute I'll attach it in der Golf bonnet so I have the rally rabbit.
Need a sunny day to take a pic of'em.
Been foggy/cloudy/poor sunny/dark today.
Easter is in the air.
1) light converted from MES to ESS (Edison screw soldered)
2.4 watt LED round dome from @tesco 50p held in place
By @parksafe2 insulation tape & wires extended using
Bit of a #saxo loom from @citroenuk loom its bright
Brughter than Vic.
2) disabled OEM therostat
3) installed #aftermarket thrmostat fresh from
#china ?6 using stolen yellow scaffolders tape
To hold the sensor.
4) rerouted the sensor up the drain tube.
5) water evaporater, converted from two screw
Fixing to one - lug snapped whilst trying to remove
The cable
#pimpmyfridge
Electrolux fridge opened door leaking water from the bottom.
You're like OH NO have to empty the rear tray, so you hugs the fridge and carry him out, but the tray is dry
as a camel.
So you take a cooper 13AWG 12 inches and stuff it in the drain tube.
No joy. Try'n'try and horray the wires go all the way down.
Rinse and repeat, clean the internal bottom, close door, hughs the fridge and carry him in its original position.
“We are encouraged to see that The Sun newspaper has carried out an investigation into companies offering odometer adjustment services”, said Sue Robinson, Director of the National Franchised Dealers Association (NFDA) which represents franchised car and commercial vehicle retailers across the UK, commenting on the issue of mileage fraud.
Move irrplaceable rusty fuel tank from garage to shed.
Dug a whole in the dark
squirted poundlabd weed killer on sonebodys over ganging truffud
chucked lump of concrete in recycking bin (sshh)
chucked bucjet of burbt rysty nails in the trash
One customer: <<Me vacuum cleaner shut down and die speed control is not funktioning>>
So you remove 7 phillips screws disconnect die speed reggaelator you grab your
trusty annaalog ohmeter you turn the knob and see the niddle is in the ohm range
high-high-high-high-high-high-high-high-high-high-high-high-high-high-high-high-high-high-
high-high-high-high-high-high-middle-middle-middle-middle-middle-low-low-low
So die logaritmic potentiometer is working.
You remove 2 more screws and you watch the pcb and oooooohhhhh there you are one of the anode
terminal of the triac has a tiny tiny crack just after the anode pad.
So you cut a 1.6 inches wire 15 AWG you grab your trusty iron solder following the route not doing
again that silly 90 degrees route that is cracked because of vibration.
You sold the wire, put everything back together, turn the knob to min, start the vacuum VROOOOOOOOOOOOOMMMMM die jet motor is now spinning at idle , turn die knob just a little
and can you breath??? So powerfull.
Another happy clean customer.
