Can't load new games. HELP please.
  • jimja
    • Feb 2011
    • 88
    #16
    Originally posted by greggthe1
    Hi mate been on hols and just trying to sort this out again. Trying to open the hacks link but it won't open? Saying file invalid?
    the link works ok I have just downloaded it. and it opens with winrar.
    • ck-ok
      • 2592
      #17
      Bigger problems now.
      I have downloaded the safe upgrade and moved the apps floder to sd card like it said and went to open it with homebrew but no sign of the apps folder on the list???
      Also my wii can't find my external hard drive to load games from coverfloader or read any origional games???
      HELP!!!!
      you dont put the apps folder in the apps folder of sd card just put in the updater folder
      • jimja
        • Feb 2011
        • 88
        #18
        HELP!!!!
        Nasty... no idea about the disc issue and that...
        but this may help.. using winrar extract the folder safeupdate to the apps folder on the sd card if there isnt one,make one, the path shld be apps/SafeUpdate
        launch hbc press 1 and make sure your looking on the sd card for it.. (this maybe a different command in HBC1.06 as i have never used it) and you should have an app now called safeupdate.
        • greggthe1
          • Apr 2011
          • 29
          #19
          I have just put the updated apps folder on root of sd card but hbc is not picking up either apps folder??
          • greggthe1
            • Apr 2011
            • 29
            #20
            I can open the rar file fine but the 2nd zip file won't open?
            • ck-ok
              • 2592
              #21
              you only need one apps folder and put all your apps in it.
              what happens when you start homebrew channel?
              • greggthe1
                • Apr 2011
                • 29
                #22
                Tried this and worked so just waiting for it to load up now!! Thanks.
                • greggthe1
                  • Apr 2011
                  • 29
                  #23
                  I've followed the instructions jimja gave me and i'm busy loading the safe update now.
                  Just need to try and sort the 4.2 hacks out next and hope my wii will find the hard drive.
                  Cheers for all your help lads, hopefully i'll soon have this sorted out
                  • greggthe1
                    • Apr 2011
                    • 29
                    #24
                    no its not the sd card if i was you i would do a safe update to 4.2 using this Digital Kaos - Downloads - v4.2 safe firmware updater then use the hacks for 4.2
                    Think the safe update is almost finished but i still can't open the priloader hacks zip. Can i get it anywhere else?
                    • greggthe1
                      • Apr 2011
                      • 29
                      #25
                      Loaded the safe 4.2 update onto wii but it seems to have knocked priiloader off. Will i re-install it?
                      Still can't load a game disc or find the external hard drive tho!!!
                      Unable to read disc error coming up for game disc's
                      Can't find usb device for hard drive.
                      • jimja
                        • Feb 2011
                        • 88
                        #26
                        id try and download again it works fine with me and winrar
                        are u sure its gone? try reinstalling.
                        • ck-ok
                          • 2592
                          #27
                          yes you will need to reinstall priiloader
                          • greggthe1
                            • Apr 2011
                            • 29
                            #28
                            I've loaded priloader back on and it's fine.
                            It's the zip file i can't open mate the priloader 4.2 hacks, trying to open with winzip and it's saying the file is empty?
                            Anyone got any idea why i can't load my games or harddrive? it was all working before but not now.
                            • greggthe1
                              • Apr 2011
                              • 29
                              #29
                              Will i need to reinstall coverfloader to get it to pick up usb hard drive?
                              • jimja
                                • Feb 2011
                                • 88
                                #30
                                google winrar use that.. not sure about winzip
