Can't load new games. HELP please.
  • greggthe1
    • Apr 2011
    • 29
    #31
    Originally posted by jimja
    id try and download again it works fine with me and winrar
    are u sure its gone? try reinstalling.
    Just tried opening it with rar and still no joy.
    • ck-ok
      • 2592
      #32
      try downloading the hacks from here http://www.digital-kaos.co.uk/forums...v0-7-a-204352/ these should work for all system menus
      • greggthe1
        • Apr 2011
        • 29
        #33
        Got priiloader 0.7 running now but when i go to system hacks it is still saying it can't findhacks.ini file
        • ck-ok
          • 2592
          #34
          try this download hacks_4.x.zip - nusad - Priiloader 4.1,4.2,4.3X Hacks.ini (http://gbatemp.net/t237575-4-1x-4-2x-4-3x-hacks-ini) - supporting files for nusad - Google Project Hosting
          • greggthe1
            • Apr 2011
            • 29
            #35
            Cheer's i'll try this one in morning.....better get some sleep for work.
            When i get this sorted out will it get my games and hdd back up and running?
            • greggthe1
              • Apr 2011
              • 29
              #36
              This is the message i get when i go into system hacks
              can't find fat:/apps/priiloader/hacks.ini
              can't find Hacks.ini on NAND
              The file is on the root of sd card but just not finding it?
              • greggthe1
                • Apr 2011
                • 29
                #37
                Still not working. Just not picking up the hack.ini file
                Kids are doing my head in asking to play on wii but i can't load any games on it anymore.
                Anyone on here live in the North East that could look at it as i'm struggling big time.
                Just keeps coming up with the message that i posted above!
                • jimja
                  • Feb 2011
                  • 88
                  #38
                  Priiloader 1.07 - The hacks file now needs to go inside the priiloader folder which is inside the apps folder. not the sd
                  its a change from 1.06
                  • greggthe1
                    • Apr 2011
                    • 29
                    #39
                    Cheers. Does it matter which hacks file i use? Been given loads now.
                    Do i need to reinstall priiloader of just go to system settings for hacks?
                    • jimja
                      • Feb 2011
                      • 88
                      #40
                      hacks.ini (should be the one) put it in the folder.. then reboot to priiloader and go into settings it should have a big long list of hacks you want to block system & Disc updates 2 in total you can enable more if you like but if you dont understand what they do see CKs post on priiloader .07.
                      it also has the hacks file in the download
                      • greggthe1
                        • Apr 2011
                        • 29
                        #41
                        Ok so now i'm on version 4.2 with the priiloader hacks finally installed
                        Got my origional games loading fine but still can't open my external hd using coverfloader? do i need to find and install coverfloader again?
                        Also went to put in one of my new games cod black opps and got a blue screen with 002 error on.
                        The new lego starwars 3 works fine now tho.
                        So just need coverfloader working and cod to play now, any ideas?
                        Thank you so much for your help lads!!!!!!
                        Great forum by the way to anyone looking in!
                        • ck-ok
                          • 2592
                          #42
                          jimja your correct on the hack files now going in the priiloader folder iv'e changed my priiloader post.
                          cheers
                          • jimja
                            • Feb 2011
                            • 88
                            #43
                            I dont know about coverloader mate i use wiiflow this has an 002 fix and works with everything so far
                            • jimja
                              • Feb 2011
                              • 88
                              #44
                              cheers
                              Your welcome CK its nice to give something back to you guys!
                              • ck-ok
                                • 2592
                                #45
                                coverfloader should have 002 fix and a auto update button in the coverfloader settings
                                if you have a old version try here wiicoverflow - CoverFloader - Google Project Hosting
