DRIVER
  • REDBEIRON
    • Sep 2011
    • 4
    #46
    read driver sf
    so i download the game and it was .wbfs so i used wbfs manager to covert the game and on the wii menu i see the game tho useing any loader to play the game does not load say can not read disc and i have plenty on disc so what now
    • REDBEIRON
      • Sep 2011
      • 4
      #47
      usb loader gx for driver:sf
      hi guys im try to use usb loader gx to load the disc i click mount drive or dvd and nothing happens help plz
      • Keithuk
        • 2264
        #48
        Well if the file you downloaded had a wbfs extension then WBFS Manager won't convert it to an iso well it won't on my 3.0.1 you need Wii Game Manager 1.5.0.2 or Wii Backup Manager.
        Keith
        2010 Golf GTD (170)
        • REDBEIRON
          • Sep 2011
          • 4
          #49
          ya i got the game to work now but now i cant play no more because i get to the mission where you get that gang guy stash back drive him home and then right there is where screen goes black and locks and cant figure how to load game with usb loader gx some said you could mount disc and play with out usb but cant figure it out see the mount but when i hit it nothing happens just cd spins anyone that can help me play this
          • Ahwahneehee
            • Sep 2011
            USB Loader
            Will this game work with the latest USB loader GX v2.2 or do you still need to patch it using Driver San Francisco Fix.
            • bluebottle
              • 71
              #51
              I just installed NeoGammaR9beta50 this morning and Driver ran fine (to my amazement). It did recommend the the new DX2 cios? but I didnt bother with that. Hope this helped, it worked for me cant say if its the cure all but give it a try.
              • REDBEIRON
                • Sep 2011
                • 4
                #52
                ok this is what i get i did the driver:sf fix in post #9 and used usb loader cfg and neogamma r9 47 and got all the way up to where you have to get vinny's stash back and then take him back home locks and you can't move on threw the game tho after each mission before that you would get the black lock up screen and you would have to restart wii by cutting the power off then back on but with the driver:san fricisco fix in post #9 and the post #51 combined it fixes the game no more lock up and countue playing thanks for all the help this works for burn disc at 1x on imgburn on dvd-r and also usb drives so use neogamma r9 beta 50 and the fix from post 9 also can use usb loader Gx thanks again post #9 and #51 i hope this helps all in getting this to work for them does for me
                • Gabster
                  • Sep 2011
                  I don't mind restarting my wii after each mission for now while I'm using cfg loader, I'm sure they'll come out with a better fix later on anyways.
                  • Keithuk
                    • 2264
                    #54
                    Here is another guide for Driver: San Fransisco which is basically for USB Loader GX.
                    Keith
                    2010 Golf GTD (170)
                    • happy_highlander
                      • 3535
                      #55
                      That is the d2x method and requires you to install all cios from the start (essentially a full soft mod from after installing hbc) to make sure it works properly. You can just install the d2x cios for driver but it may not work properly
                      • mikey533
                        • Sep 2011
                        • 5
                        #56
                        Driver San Fran Fix
                        So if I download the fix in post 9, it wont freeze on the loading screen in story mode? and the game will be 100% playable without any freezing?
                        • happy_highlander
                          • 3535
                          #57
                          That is correct follow all the instructions that come with the fix file installing both gx and the iso patch. Black ops will still play after this fix has been installed
                          • mikey533
                            • Sep 2011
                            • 5
                            #58
                            Driver San Fran Fix
                            Hey Highlander I already have USB LOADER GX installed, should i override it with the one in the fix file?
                            • happy_highlander
                              • 3535
                              #59
                              Yes it is the newest version and is required for the fix to work
                              • mikey533
                                • Sep 2011
                                • 5
                                #60
                                Its still not working it says ios 56 v. 5661 and 57 is what version you mention i'm about to give up and buy the game.
