Im having the same issue here. my HDD doesn't get detected, though my usbloader gives the time out 'waiting for HDD' message.
usb loader cant find HD
Here it is. Any help would be great!
sysCheck v2.1.0b18 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: NTSC-U
System Menu 4.3U (v513)
Drive date: 2007.02.13
Homebrew Channel 1.1.0 running on IOS58
Hollywood v0x11
Console ID: 113373250
Boot2 v4
Found 80 titles.
Found 48 IOS on this console. 16 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS224 (rev 5661): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS248 (rev 5661): Trucha Bug, NAND Access
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2013/01/04.Comment
Welcome to DK Crombinator.
This is a common problem which I've give the solution to many times so read it yourself post #50.
Keith
2010 Golf GTD (170)Comment
I'm having the same issue. USBLoaderGX is not detecting my HDD anymore.
sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
Region: NTSC-U
Drive date: Unknown
HomebrewFilter ist nicht installiert
Console ID: 44436211
Boot2 v4
Found 111 titles.
Found 48 IOS on this console. 12 of them are stub.
IOS36 (rev 3608): No Patches
IOS80 (rev 6943): Trucha Bug, NAND Access
IOS202[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 65535, Info: hermes-v5.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[37] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
IOS249[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
IOS250[37] (rev 20, Info: rev 20): Trucha Bug, NAND Access, USB 2.0
IOS253[37] (rev 21006, Info: d2x-v6): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v10
Report generated on 2013/09/01.
I'm going to try and install the 7 wads from d2x v8.0 final wad pack.
Any other reccomendations?Comment
What do you mean it used to detect it before I don't see IOS236 listed?
Well your sysCheck is typical Wii thats only been softmodded but you only have 12 stubs which you have to knock down to about 5.
You need to download ModMii 2.4 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
This will download all files into COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted. ModMii only adds 2 d2x v8.0 wads so install all 7 wads from d2x v8.0 final wad pack after you've added them to the wad folder on the SD card.
Run IOS236 installer from Homebrew first to install IOS36 into IOS236, you must do this before you install any other wads. Come back out then run Multi-Mod Manager and select WAD Manager and install all wads in that folder. I've posted this method in many threads on here if you read them.
You can run sysCheck again and post a new sysCheck report afterward installing all the wads.Keith
My USBLoader GX was detecting the hard drive earlier today, until I updated my Homebrew Browser from v0.3.9c to 0.3.9e. When I went back into the USBLoader, it was no longer detecting the hard drive.
I followed your instructions to the best of my ability but it still isn't detecting the hard drive. Here is the new report:
Region: NTSC-U
Drive date: Unknown
Boot2 v4
Found 118 titles.
Found 55 IOS on this console. 4 of them are stub.
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS62 (rev 6430): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v10
Report generated on 2013/10/01.
Any suggestions?Comment
That new sysCheck looks ok.
Well the truth is coming out now this only happened after you updated Homebrew Browser from v0.3.9c to 0.3.9e. I had version 0.3.9c and I downloaded 0.3.9e and ran it with no problems.
I tried a couple of games on the HDD and they still work. I don't know what to suggest really only put 0.3.9c back and check its settings. I'm not sure how your drive is formatted but Disable USB mount.
Have you updated the Shopping channel? RVL-Shopping-21Keith
Have to reconnect USB every time
Hi,
My USB actually works, but everytime I start the Wii, Loader GX cannot see the USD-drive. So I have to detach the drive from the port, start GX again, and the wait for it to tell me, that I have a slow device. Then I insert the USB again, and everyting works.
I have to do this every time I want to play.
Any ideas what is wrong? I use a 2,5' drive powered by the USB.Comment
Welcome to DK.
Without repeating myself yet again what we need to see is a sysCheckb19 report as instructed in that link. Now you've made 1 post you should be able to download.Hi,
Apart from the obvious the drive isn't compatible or its a USB powered drive or the drives isn't formatted corectly for the games you've added.
Some drives do take a while to spin up.Keith
Now with Syscheck
I know, but had to make a post to be able to download.
I have just softmodded the Wii (new to this), and I start in normal Wii-menu, go to HomeBrew and load GX. Most of the times GX cannot see the USB-drive, but if I wait to connect it, after loading GX, and GX say 'waiting for slow drive' it works, I can play all backups, but this is quite annoying. So I guess it's modded correct, and that the drive is compatible, otherwise it wouldn't work this way I quess. The drive starts as soon as I start the wii, and since I load GX manually I quess it has spinn-up. It's a WBFS-drive, 2,5' powered by USB.
My syscheck says:
Region: PAL
System Menu 4.3E (v514)
Drive date: 2008.07.14
Hollywood v0x21
Console ID: 99006948
Boot2 v4
Found 75 titles.
Found 48 IOS on this console. 15 of them are stub.
IOS3 (rev 65280): Stub
BC v6
MIOS v10
Report generated on 2013/01/10.Comment
Well I've posted what you need to do higher up this page if you read.
I wonder why you've installed only 2 d2x v8.0 wads?Well your sysCheck is typical Wii thats only been softmodded but you only have 15 stubs which you have to knock down to about 5.
After you've installed all the missing wads post a new sysCheck.Keith
I used this guide https://sites.google.com/site/comple...s/installation
Where only 249 and 250 are used.
But since I can actually use the backups, just having trouble with using the usb-drive without having to disconnect and then reconnect, can that have anything to do with what you say?Comment
