i'm using wii backup manager to install games. i'm getting some to work but not others. not sure what i'm doing wrong (or right) still learning. any ideas.
usb loader gx problem
More info required wii version and softmod method used plz and/or syscheck -
Welcome to the Nintendo Wii section.
I think all of your 408 posts are football related.
As HH said we need more info. If you can post a sysCheck report that would be very helpful. Please show the report as instructed in the thread open it with WordPad not NotePad and copy and paste the text.
Also tell us which USB Loaders you are using?Keith
2010 Golf GTD (170)Comment
right i've finally managed to to do it
Region: PAL.
Hollywood v0x11.
Boot2 v4.
System Menu v514 (4.3E).
BC v6.
MIOS v10.
Found 98 titles.
Found 46 IOS and 5 IOS Stubs on this console.
Priiloader is installed.
IOS 4 (rev 65280): Stub
IOS 9 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 10 (rev 768): Stub
IOS 11 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 12 (rev 269)
IOS 13 (rev 273)
IOS 14 (rev 520)
IOS 15 (rev 523)
IOS 16 (rev 54321): Trucha Bug, ES_Identify, FLASH Access, NAND Access
IOS 17 (rev 775)
IOS 20 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 21 (rev 782)
IOS 22 (rev 1037)
IOS 28 (rev 1550)
IOS 30 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 31 (rev 3608)
IOS 33 (rev 3091)
IOS 34 (rev 3348)
IOS 35 (rev 3349)
IOS 36 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 37 (rev 3869)
IOS 38 (rev 3867)
IOS 40 (rev 3072): Stub
IOS 41 (rev 3607)
IOS 43 (rev 3607)
IOS 45 (rev 3607)
IOS 46 (rev 3607)
IOS 48 (rev 4124)
IOS 50 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 51 (rev 4864): Stub
IOS 52 (rev 5888): Stub
IOS 53 (rev 5406)
IOS 55 (rev 5406)
IOS 56 (rev 5662)
IOS 57 (rev 5661)
IOS 58 (rev 6176): USB 2.0
IOS 60 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 61 (rev 5662)
IOS 70 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 80 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS 90 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS202 (rev 65535): Trucha Bug, ES_Identify, NAND Access, USB 2.0
IOS222 (rev 4): Trucha Bug, ES_Identify, NAND Access, USB 2.0
IOS223 (rev 4): Trucha Bug, ES_Identify, NAND Access, USB 2.0
IOS224 (rev 65535): Trucha Bug, ES_Identify, NAND Access, USB 2.0
IOS236 (rev 54321): Trucha Bug, ES_Identify, NAND Access
IOS247 (rev 65535): Trucha Bug, ES_Identify, NAND Access
IOS248 (rev 65535): Trucha Bug, ES_Identify, NAND Access
IOS249 (rev 20): Trucha Bug, ES_Identify, NAND Access
IOS250 (rev 65535): Trucha Bug, ES_Identify, NAND Access
IOS254 (rev 65281)
Report generated on 2012-02-14.
softmodded via letterbomb
Men of Harlech onto glory
This shall ever be your story
Keep these fighting words before ye
Cambria will not yieldComment
Way out of date m8 copy this to a blank sd card Digital Kaos - Downloads - Full Cios wad pack then select mmm from hbc..Reload to ios 236 if your not already on it when mmm starts....once your on 236 navigate to wad manager and select it then press "1" on the wiimote to select all wads for batch install and press "a" to install watch the screen and make sure they all install without error..if they don't go back and install the ones that didn't work individually..That will bring you up to date with cios for game play and as long as you are using usbloader gx version 2.3 then everything will work fine except for tintin which will still freeze at every checkpoint...All the call of duty games will load from ios 250 and almost all others wil load from 249 bar mic games which use 223 or 224right i've finally managed to to do it
Region: PAL.
Hollywood v0x11.
Boot2 v4.
BC v6.
MIOS v10.
Found 98 titles.
IOS 12 (rev 269)
IOS 13 (rev 273)
IOS 14 (rev 520)
IOS 15 (rev 523)
IOS 17 (rev 775)
IOS 21 (rev 782)
IOS 22 (rev 1037)
IOS 28 (rev 1550)
IOS 31 (rev 3608)
IOS 33 (rev 3091)
IOS 34 (rev 3348)
IOS 35 (rev 3349)
IOS 37 (rev 3869)
IOS 38 (rev 3867)
IOS 41 (rev 3607)
IOS 43 (rev 3607)
IOS 45 (rev 3607)
IOS 46 (rev 3607)
IOS 48 (rev 4124)
IOS 53 (rev 5406)
IOS 55 (rev 5406)
IOS 56 (rev 5662)
IOS 57 (rev 5661)
IOS 61 (rev 5662)
IOS254 (rev 65281)
softmodded via letterbombComment
There is no chance of anything going wrong if you follow the instructions as this is a just a cios update and doesn't touch the system ios...Yes you will have all channels that you did have before, you may need to update all your loaders i.e neogamma and any usb loader you use. Although the cios are important to get the games to run the loaders also help bypass any ap and work alongside the cios so the most up to date loaders are requiredComment
thanks i've updated it all no problems. i now need to update usb loader gx, i currently have 1.0. how do i go about this. i've seen a couple on here but don't know which to use. i've tried updating on the wii but keep getting errors
Its strange it won't update online through WiFi mine did.
You can always download 2.3 direct and stick it on your SD card USB Loader GX along with the forwarder channel if you don't have one. USBLoader_GX_V2_3_AllinOnePackage_IOS249.zipKeith
Gx does not like updating from version 1 to version 2 mate that's why it may not be updating online. If he installs everything to do with gx then follows your link to the all in one pack he will be fine.Its strange it won't update online through WiFi mine did.
You can always download 2.3 direct and stick it on your SD card USB Loader GX along with the forwarder channel if you don't have one. USBLoader_GX_V2_3_AllinOnePackage_IOS249.zipComment
