USB Loader GX Forwarder channel Forwarder. Put it in the wad folder on the SD card and install it will MMM job done.
usb loader gx problem
The forwarder cannot find the .dol gx file. You must have the structure wrong on the sd or usb as that forwarder will launch from both, can you post your file path and files that are in the gx folder please, starting from what is on the root of the sd card, please type the folder name as you see them i.e upper or lower case.Comment
ForwarderV4 , dol file
GXGameSettings.cfg , cfg file
GXGameStatistics.cfg , cfg file
theme , file folder
boot , dol file
GameTimestamps , txt file
GXGlobal.cfg , cfg file
icon , png image
meta , xml file
TitlesCache , vlc media file
images , file folder
Men of Harlech onto glory
This shall ever be your story
Keep these fighting words before ye
Cambria will not yieldComment
And you have all that lot in the gx folder..........you should have boot .dol file (not forwarder dol), icon png file and meta xml file. The biggest problem you will be having is that you have 2.dol files. Copy the files you have then delete all except the three I have just told you, gx will create any more it needs, those three are the only files in a clean setup, you can then add theme and settings files one at a time afterwards but not the forwarder dol that way if it stops working you will know which file is bad as it will be the last one addedLast edited by happy_highlander; 23 February, 2012, 22:05.Comment
where did you get the file from ?????? I think you are trying to use the wrong file from the all in one pack. Extract this file to a blank sd card Digital Kaos - Downloads - Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 you don't need everything that's in it but it has the correct file structure. I am assuming you have already installed the gx forwarder wad so that you have a channel on the main wii screen. If this works for you then just use the gx folder from it and put it in your apps folder or keep this structure and just move over any apps you want from your sd card into the apps folder from this file....If you don't have a forwarder channel installed there is one in the wads folder and install instructions in the file...Comment
One more thought mate your syscheck doesn't say what version of hbc you have or what ios it is running on.....The v4 gx forwarder channel will only work on ios 58 which I know you have.Comment
It sounds like you've cocked something up there.
Download USB Loader GX Easy installer (for Windows). put the SD card in your computer and look at the files. Delete the config folder if you have one. Delete apps\usbloader_gx folder. All that should be in that usbloader_gx folder initially is boot.dol - to run the app, icon.png - the picture that shows in HBC, meta.xml the app settings. It may have rev.txt and GameList.txt. All the other files you have listed should be in the config folder.
Run USBLoaderGX_Installer.exe that will put all the necassary files on the SD card to run USB Loader GX from HBC. You will have to download the pictures for the games you have on the drive. You click on the 5th icon along the top which will show a picture with a ? in it on the left and the list of games on the right. You can click on the fan icon after the pics have downloaded. Click on a game picture to show the game info\setting click the disc to run it.
While you are on that site download the USB Loader GX-UNEO_Forwarder_4_0_AHBPROT.wad put that in the wad folder and install it with MMM. That will put the USB Loader GX channel on the Wii menu so you don't have to use HBC to run the loader.
Once the loader works you can click on Settings and update to the newest version if you not running 2.3. If it updates shut it down and restart it to take effect.
My forwarder is USB Loader GX-UNEO_Forwarder.wad but that one should work.Keith
2010 Golf GTD (170)Comment
i've tried this still no joy. i have the channel installed. homebrew is version 1.0.8 iso58 v24.32 i thinkwhere did you get the file from ?????? I think you are trying to use the wrong file from the all in one pack. Extract this file to a blank sd card Digital Kaos - Downloads - Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 you don't need everything that's in it but it has the correct file structure. I am assuming you have already installed the gx forwarder wad so that you have a channel on the main wii screen. If this works for you then just use the gx folder from it and put it in your apps folder or keep this structure and just move over any apps you want from your sd card into the apps folder from this file....If you don't have a forwarder channel installed there is one in the wads folder and install instructions in the file...Last edited by bowie; 25 February, 2012, 09:10.
i,m trying to download that installer but keep getting this message:-It sounds like you've cocked something up there.
download failed: HTTP/1.1 404 Not Found
