usb loader gx problem
  • bowie
    • 475
    #31
    here you go
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priilaoder installed
    Homebrew Channel 1.0.8 running on IOS58
    Hollywood v0x11
    Console ID: 77775946
    Boot2 v4
    Found 109 titles.
    Found 54 IOS on this console. 5 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 54321): Trucha Bug
    IOS10 (rev 768): Stub
    IOS11 (rev 54321): Trucha Bug
    IOS12 (rev 269): No Patches
    IOS13 (rev 273): No Patches
    IOS14 (rev 520): No Patches
    IOS15 (rev 523): No Patches
    IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS17 (rev 775): No Patches
    IOS20 (rev 54321): Trucha Bug
    IOS21 (rev 782): No Patches
    IOS22 (rev 1037): No Patches
    IOS28 (rev 1550): No Patches
    IOS30 (rev 54321): Trucha Bug
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3091): No Patches
    IOS34 (rev 3348): No Patches
    IOS35 (rev 3349): No Patches
    IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS37 (rev 3869): No Patches
    IOS38 (rev 3867): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 54321): Trucha Bug
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5406): No Patches
    IOS55 (rev 5406): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5661): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 54321): Trucha Bug
    IOS61 (rev 5662): No Patches
    IOS70 (rev 54321): Trucha Bug
    IOS80 (rev 54321): Trucha Bug
    IOS90 (rev 54321): Trucha Bug
    IOS202[60] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2012/02/25.
    Men of Harlech onto glory
    This shall ever be your story
    Keep these fighting words before ye
    Cambria will not yield
    • Keithuk
      • Aug 2010
      • 2264
      #32
      Originally posted by bowie
      i,m trying to download that installer but keep getting this message:-
      download failed: HTTP/1.1 404 Not Found
      I've just downloaded and that link is ok. Just click on View under USB Loader GX Easy installer (for Windows).
      If your still having problems then I'll add it as a zip if your still stuck.
      Have you installed the Forwarder wad?
      That sysCheck looks ok to me.
      Keith
      2010 Golf GTD (170)
      • happy_highlander
        • Aug 2010
        • 3535
        #33
        As keith says syscheck is fine something is screwed up in the file structure for gx. Did you try formatting the sd card and extracting the gx file i linked you to straight onto it...(don't extract then copy and paste) select the sd card as the extraction destination with winrar
        • bowie
          • 475
          #34
          still getting the same message for that installer and ive downloaded the forwarder wad no probs
          • Keithuk
            • Aug 2010
            • 2264
            #35
            Ok if you still having problems downloading USBLoaderGX_Installer.exe try this. As I've said I've just downloaded it no problem.
            Sorry I've just saved this zip and it wouldn't open I've just uploaded again.
            I've just try it again and it still won't open. The original zip opens perfectly.
            bowie just keep trying the link until it works.
            Keith
            2010 Golf GTD (170)
            • bowie
              • 475
              #36
              i just cant open it keep getting the same error
              • bowie
                • 475
                #37
                still cant do it.
                can explain step by step exactly what i need to do because i'm obviously missing something. sorry to be a pain
                • happy_highlander
                  • Aug 2010
                  • 3535
                  #38
                  still cant do it.
                  format the sd card you are going to use to either fat or fat 32 (must be smaller than 2gb and not sdhc, make sure to keep all the files you need) right click the box of books that is this file Digital Kaos - Downloads - Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 then select extract files and in the new box click display then scroll down to the newly formatted sd card select it then select ok that will extract them straight onto the sd in the correct folders and file paths..You then put the sd card in the wii and click the gx forwarder channel this will load gx and all should now be working
                  • Keithuk
                    • Aug 2010
                    • 2264
                    #39
                    still cant do it.
                    Still can't do what download USBLoaderGX_Installer.exe or copy the files onto the SD card?
                    I don't know whats wrong with your browser as I've just downloaded USBLoaderGX_Installer.exe yet again perfectly.
                    As I said previously once you download the exe you insert your SD card into your computer. Open it up to you can see the files\folders. Delete apps\usbloader_gx folder and the config folder on the root.
                    You then run USBLoaderGX_Installer.exe and it writes all the correct files on the SD card in the correct folders.
                    Keith
                    2010 Golf GTD (170)
                    • Keithuk
                      • Aug 2010
                      • 2264
                      #40
                      You can use a SDHC card formatted FAT32 on a 4.0+ Wii after you have softmodded I use a 4GB SDHC card in mine.
                      Just browsing through this thread and it appears the if GX is bouncing back to thw Wii menu then your HDD isn't recognised do you have a USB Compatible Drives?
                      Instead of using Wii Backup Manager to add files to your drive use WBFS Manager as its simple and easy to use.
                      Keith
                      2010 Golf GTD (170)
                      • happy_highlander
                        • Aug 2010
                        • 3535
                        #41
                        the hdd is recognised keith the initial problem was some games weren't working and some weren't now gx wopn't load at all
                        • kurariahunter
                          • Feb 2012
                          I was curious if anything has figured out how to load wedare or wiidare?
                          • Keithuk
                            • Aug 2010
                            • 2264
                            #43
                            I've never heard of wedare or wiidare but here is Wii Dare.
                            [ame="http://www.youtube.com/watch?v=m2Uh0EDBPM8"]Wii Dare For Adults - YouTube[/ame]
                            or are you thinking of Wiiware?
                            Keith
                            2010 Golf GTD (170)
                            • reddevil157
                              • 1427
                              #44
                              , can see it now.... a load of beer, a few friendly couples round, & this starts.......~~~~in murders
                              • bowie
                                • 475
                                #45
                                sorry i havent been able to do anything until today.
                                i did what you said but now usb loader gx wont load at all from the wii menu. all i have on the sd card is the above file
