usb loader gx problem
  • sam9s
    • Mar 2012
    • 5
    #76
    Originally posted by happy_highlander
    Ok mate try this, first of all make sure you don't have anything to do with usbloader gx on your wii or on your sd card then put this apps folder onto the sd card, put the card into the wii and launch hbc you should see usb loader gx app. Launch that from inside hbc and let me know how you get on shout up is this link doesn't work it's the first time I've tried it http://dl.dropbox.com/u/64422396/apps.rar
    Hi highlander,
    I am also new to all this and just bought a wii, (system menu 4.3E) I have hacked it and loaded the HBC and emulators are working fine. Now even I am getting the same error "download failed: HTTP/1.1 404 Not Found" while installing the loader GX. I tried your uploaded GX loader file and I was able to see Loader gx app under HBC. HOw ever when I try to load it it gives me the error .... "USB Loader requires atleast cIOS 222 or 245-250."
    I then followed your this post /......
    Here you go bowie http://dl.dropbox.com/u/64422396/gx%...0and%20mmm.rar Extract this to the sd card that has the working gx on it, you then drag the mmm folder into the apps folder. put the sd into the wii and launch hbc, form there start mmm (multi mod manager) navigate down to reload ios (bottom of the list i think) then select 236 from the options...once reloaded go to wad manager and select it, now press "a" to select forwarder wad and "a" again to install it. Exit mmm and hbc and go to the main wii screen, you should now have a gx channel on your main screen click that and gx should now load properly for you.
    Now in this when I navigate to reload ios I do not see the option 236 there. I see 3,4,9 ...uptill 70, 80 and then 222, 223, 249,250 and last 254. But if i try to load 222 or 223,249,250 it says "Not loading stu IOS" On 254 it just hangs on reloading IOS254 and I have to power off it to bring it online .....
    Can you guide me, how to get GX Uploader working ....
    Any help would be highly appriciated .....
    Thanks in advance
    regards
    sammy
    • ck-ok
      • 2592
      #77
      Originally posted by sam9s
      Hi highlander,
      Thanks in advance
      regards
      sammy
      what tutorial did you follow?
      try installing Digital Kaos - Downloads - ios236 v54321 wad so you can follow h-hs guide it will also help if you post a Digital Kaos - Downloads - sysCheck v2.1.0 Beta 11
      • happy_highlander
        • Aug 2010
        • 3535
        #78
        It sound as though he has stubbed out all vulnerable ios ck so your second link of a syscheck will probably be his best bet so that we can make sure that's what has happened
        • ck-ok
          • 2592
          #79
          thats what i thought h-h sounds like he has updated
          • sam9s
            • Mar 2012
            • 5
            #80
            Ok I was not following any tut up till now, when I kinda googled more about this and came to know that you need to have a customOS in order for GX installer to work. I then followed the followinf guide but without success ...
            We Hack Wii / USB Loader
            I skiped 1-4 as I already had hacked the wii. Rest were followed per the sequence. I was successfully able to delete the stub 222, and all other that the guide said to remove. But when I go to step 7 where we actually install cIOS, it seems to do its part but at the end I get the following line .....
            Downloading part 1/15, SD Card . Bad Hash
            and then just exits.
            On step 8 it gives error ret = -2011
            Now if I try to load GX Loader it gives the error .....needs unstubbed cIOS 222 v4 or 249 v9 .......and then exits.
            cIOS is the one I am trying to install on step 7, but obviously somewhere something is going wrong ...
            Help!
            My syscheckl is as follows
            sysCheck v2.1.0b11 by Double_A and R2-D2199
            ...runs on IOS58 (rev 6176).
            Region: PAL
            System Menu 4.3E (v514)
            Homebrew Channel 1.0.0 running on IOS58
            Hollywood v0x21
            Console ID: 169610702
            Boot2 v4
            Found 62 titles.
            Found 39 IOS on this console. 10 of them are stub.
            IOS3 (rev 65280): Stub
            IOS4 (rev 65280): Stub
            IOS9 (rev 1034): No Patches
            IOS10 (rev 768): Stub
            IOS11 (rev 256): Stub
            IOS12 (rev 526): No Patches
            IOS13 (rev 1032): No Patches
            IOS14 (rev 1032): No Patches
            IOS15 (rev 1032): No Patches
            IOS16 (rev 512): Stub
            IOS17 (rev 1032): No Patches
            IOS20 (rev 256): Stub
            IOS21 (rev 1039): No Patches
            IOS22 (rev 1294): No Patches
            IOS28 (rev 1807): No Patches
            IOS30 (rev 2816): Stub
            IOS31 (rev 3608): No Patches
            IOS33 (rev 3608): No Patches
            IOS34 (rev 3608): No Patches
            IOS35 (rev 3608): No Patches
            IOS36 (rev 3608): No Patches
            IOS37 (rev 5663): No Patches
            IOS38 (rev 4124): No Patches
            IOS41 (rev 3607): No Patches
            IOS43 (rev 3607): No Patches
            IOS45 (rev 3607): No Patches
            IOS46 (rev 3607): No Patches
            IOS48 (rev 4124): No Patches
            IOS50 (rev 5120): Stub
            IOS51 (rev 4864): Stub
            IOS52 (rev 5888): Stub
            IOS53 (rev 5663): No Patches
            IOS55 (rev 5663): No Patches
            IOS56 (rev 5662): No Patches
            IOS57 (rev 5919): No Patches
            IOS58 (rev 6176): USB 2.0
            IOS61 (rev 5662): No Patches
            IOS80 (rev 6944): No Patches
            IOS254 (rev 65281): BootMii
            BC v6
            MIOS v10
            Report generated on 2012/03/11.
            Regards
            Sammy
            • Keithuk
              • Aug 2010
              • 2264
              #81
              Welcome to DK Sammy.
              It appears a few are getting this HTTP/1.1 404 Not Found error. I downloaded USBLoaderGX_Installer.exe from another site and it shows the same error.
              When you try to run USB Loader GX from HBC it will say needs cIOS222, cIOS249 or cIOS250 as instructed install d2x v7 Final that will install all the necessary wads needed for USB Loaders.
              If you want IOS236 download it and put it in the wad folder on the SD card and install it with MMM along with the other d2x v7 wads.
              I see you've post the sysCheck report and as suspected you don't have the d2x v7 wads installed, do that or you will never get USB Loaders to work.
              I also see you don't have PriiLoader 0.7 installed to block online and disc updates, install this.
              Oh after you softmodded did you do a NAND backup straight afterwards?
              Keith
              2010 Golf GTD (170)
              • ck-ok
                • 2592
                #82
                if i was you i would use Digital Kaos - Downloads - modmii 4.3.4 to download your files and write you a personalised tutorial soubd like you need one
                you can skip the part about homebrew channel as you already have it
                • happy_highlander
                  • Aug 2010
                  • 3535
                  #83
                  Help!
                  Regards
                  Sammy
                  Can't get to pc for about another half hour or so but don't go deleting any more ios until I can get a tut done for you or you are going to end up in a whole heep of sh1t.
                  Edit.....In fact follow the link from ck but you need to update hbc first as you are only running version 1.0.0 and should be on version 1.0.8 or you will not be able to install cios 236 properly and the rest of the updates will then fail.
                  • ck-ok
                    • 2592
                    #84
                    h-h just checked BootMii.org seems there is a 1.1.0 which is installed by hackmii installer v1
                    i've not heard anything about that
                    • happy_highlander
                      • Aug 2010
                      • 3535
                      #85
                      Me neither.............Away to see what i can find out
                      • happy_highlander
                        • Aug 2010
                        • 3535
                        #86
                        I've just updated my hbc to the 1.1.0 version and it does register as 1.0.0 on a syscheck ck.....So he has the latest version.......
                        • Keithuk
                          • Aug 2010
                          • 2264
                          #87
                          Did you uninstall HBC or just overwrite it?
                          Keith
                          2010 Golf GTD (170)
                          • happy_highlander
                            • Aug 2010
                            • 3535
                            #88
                            update through hbc keith it is only syscheck that is giving the wrong version hbc is recording the correct version in the top right
                            • sam9s
                              • Mar 2012
                              • 5
                              #89
                              Thanks for all the help and guidence guys ......@keithuk, I downloaded all the wads including 236 and placed them under wad folder and tried to install them using MMM and its a no go, I get the following error ...
                              Installing 1/1: IOS236-v54321.wad - Ticket (-2011)
                              Final Status - 1 did not complete
                              Press any button to continue, and this happens irrespective of
                              which wad I choose to install.
                              M gonna try the other method now provided by ck-ok if I do manage to understand it .....
                              Regards
                              Sammy
                              UPDATE :: I tried installing the same wad using the WAD manager and I get the following error
                              >> Installing Ticket .... ERROR! (ret = -2011)
                              This is the same error I got while performing step 8 of my initial tut that I was following.
                              • sam9s
                                • Mar 2012
                                • 5
                                #90
                                Not deleting any more ios highlander ... waiting for your specific instructions ....
