yeah im trying to use USBLoaderGX_Installer.exe what should I use instead? Also do i have to have the games in the same memory card or hdd as the usbloader_gx?
USB Loader GX has usbloader_gx in the apps folder and a seperate config folder on the root of the SD card which holder all the game pictures and setting files. I'm not sure if it would work if you just downloaded USBLoader_GX_V2_3_AllinOnePackage_IOS249.zip and put it on the SD card. You could install the forwarder wads so it shows on the Wii menu. I downloaded USBLoaderGX_Installer.exe along time ago when it worked perfectly.
You could try Googling USBLoaderGX_Installer.exe to see if there are any good copies out there.
You just extract all files\folders from USBLoader_GX_V2_3_AllinOnePackage_IOS249.zip to the SD card. You need to install the wads in the wad folder with a WAD Manager or MMM.
what do i did with the dol files in the USBLoader_GX_V2_3_AllinOnePackage_IOS249.zip
Originally posted by mjbush89
i mean what folder should they be in
As I said you extract ALL files and folders to the SD card.
No you don't. You put the gx folder into the apps folder and the forwarder wad into the wads folder. Unless you want to install the full channel in which case you extract the full channel wad into the wads folder. The .dol files are only required if you wish to replace only the .dol file from an existing gx folder.
