homebrew??
  • casper1690
    • Feb 2011
    • 213
    #61
    that me di my nand bk up so i thing all i gota do is get Usbloader gx 2.3 r1128 and d2x v7 with mmm onto my wii then play games???
    • happy_highlander
      • Aug 2010
      • 3535
      #62
      Originally posted by casper1690
      after i do a back up then i am able to copy usb loader to sd card the play games via my harddrive. As just wnt to play iso files
      Just follow the modmii tutorial and don't try to run before you can walk, remember more haste less speed, if you try to rush this you will make a mistake and won't know where you've went wrong then will try to fix it make another mistake and before you know it your wii is bricked, remember you only have bootmii as an ios, so a working priiloader and nand backup are essential
      • casper1690
        • Feb 2011
        • 213
        #63
        i have now hbc chan and i have usb loader chan. every time i go into usb chan it starts then goes back to homescreen. i have iso game 4.3gb wnt go on hdd as 4g most. will i try wiiback up manager??
        • happy_highlander
          • Aug 2010
          • 3535
          #64
          Yes use wiibackup manager to transfer games and allow it to create a wbfs folder
          • casper1690
            • Feb 2011
            • 213
            #65
            i have wbfs manager 2.5 0n my pc.
            i dont want to formate my fat 32 500gb drive.
            as got 100gb of files on it.
            do i need to or is there anyway around this
            • casper1690
              • Feb 2011
              • 213
              #66
              i have just formated the drive to wbfs. now goint to try tranfer iso to it and c if can play
              • casper1690
                • Feb 2011
                • 213
                #67
                i still not getting to play the game i have it on my harddrive and now when i start the usbloader then it starts and goes straight back to the start up screen.
                if i go into apps and go to usbloader (thru mmm) it shows me i have mario then i click the game and it reloads the wii back to start.
                • barrowmanandrew
                  • 3427
                  #68
                  which usb loader have you installed?
                  which settings did you choose ?
                  what files are on your harddrive?
                  • happy_highlander
                    • Aug 2010
                    • 3535
                    #69
                    No need to format gx reads from a fat 32 drive when you transfer a game with wiibackup manager it scrubs the iso and converts it to wbfs format making it smaller than 4 gb. As with the rest I can't really help you as you have not really followed any guide from start to finish but chosen to do things in fits and starts so I have no idea what files or folders you have on sd or what ios and cios have been installed. You will need to post a syscheck so I can see what you have and try to work out what guide you are closest to before we can sort anything out.
                    • casper1690
                      • Feb 2011
                      • 213
                      #70
                      Usbloader gx 2.3 r1128 and d2x v7 USB Loader GX-UNEO_Forwarder_4_0_AHBPROT (1).wad
                      i also put the above file in wad folder thru mmm
                      and i formated my harddrive to wbfs and transferd it to harddrive thre wbfs manager 2.5.
                      hoping i havent messd up as kids going on at me and i bought another wii. plus im using pages up to ask people for help and every1 b getting hacked off at me i think
                      • casper1690
                        • Feb 2011
                        • 213
                        #71
                        i am starting from beggining will do i step after step and hopeing that will sort it i sorry 4the bother will follow guide step by step in 1 go
                        • happy_highlander
                          • Aug 2010
                          • 3535
                          #72
                          Nobody is getting hacked off mate. The problem we have is there is lots of different methods that all have the same end result. No need to start from the beginning just post the syscheck file as I asked and we can sort it out.
                          • casper1690
                            • Feb 2011
                            • 213
                            #73
                            when a do system check how do i get it from wii to crd. Its just shown me the white page and then putn me bk to wii menu or shut dwn
                            • happy_highlander
                              • Aug 2010
                              • 3535
                              #74
                              So you have syscheck file in your apps folder which you launch from hbc, yes. It then gives you white screen asking to test all ios, you then press "a" this will test all ios and put a csv file on your sd. You then put the sd in the pc and right click on the csv file and select open with "wordpad" not "notepad". Save that file to pc then post it in this thread. If you cannot generate this file then you need to go back to modmii and get yourself a full tutorial and follow the guide word for word from after the hbc step as you alway have hbc, if you have already installed priiloader you can skip that bit as well.
                              • casper1690
                                • Feb 2011
                                • 213
                                #75
                                sysCheck v2.1.0b11 by Double_A and R2-D2199
                                ...runs on IOS236 (rev 65535).
                                Region: PAL
                                System Menu 4.3E (v514)
                                Priilaoder installed
                                Homebrew Channel 1.0.8 running on IOS58
                                Hollywood v0x11
                                Console ID: 81476057
                                Boot2 v4
                                Found 74 titles.
                                Found 54 IOS on this console. 5 of them are stub.
                                IOS3 (rev 65280): Stub
                                IOS4 (rev 65280): Stub
                                IOS9 (rev 1034): No Patches
                                IOS10 (rev 768): Stub
                                IOS11 (rev 16174): Trucha Bug, NAND Access
                                IOS12 (rev 526): No Patches
                                IOS13 (rev 1032): No Patches
                                IOS14 (rev 1032): No Patches
                                IOS15 (rev 1032): No Patches
                                IOS16 (rev 512): Stub
                                IOS17 (rev 1032): No Patches
                                IOS20 (rev 16174): Trucha Bug, NAND Access
                                IOS21 (rev 1039): No Patches
                                IOS22 (rev 1294): No Patches
                                IOS28 (rev 1807): No Patches
                                IOS30 (rev 16174): Trucha Bug, NAND Access
                                IOS31 (rev 3608): No Patches
                                IOS33 (rev 3608): No Patches
                                IOS34 (rev 3608): No Patches
                                IOS35 (rev 3608): No Patches
                                IOS36 (rev 3608, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                                IOS37 (rev 5663): No Patches
                                IOS38 (rev 4124): No Patches
                                IOS40 (rev 16174): Trucha Bug, NAND Access
                                IOS41 (rev 3607): No Patches
                                IOS43 (rev 3607): No Patches
                                IOS45 (rev 3607): No Patches
                                IOS46 (rev 3607): No Patches
                                IOS48 (rev 4124): No Patches
                                IOS50 (rev 16174): Trucha Bug, NAND Access
                                IOS51 (rev 4864): Stub
                                IOS52 (rev 16174): Trucha Bug, NAND Access
                                IOS53 (rev 5663): No Patches
                                IOS55 (rev 5663): No Patches
                                IOS56 (rev 5662): No Patches
                                IOS57 (rev 5919): No Patches
                                IOS58 (rev 6176): USB 2.0
                                IOS60 (rev 16174): Trucha Bug, NAND Access
                                IOS61 (rev 5662): No Patches
                                IOS70 (rev 16174): Trucha Bug, NAND Access
                                IOS80 (rev 16174): Trucha Bug, NAND Access
                                IOS202[60] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
                                IOS222[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
                                IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
                                IOS224[57] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
                                IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                                IOS245[37] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
                                IOS246[38] (rev 21007, Info: d2x-v7final): Trucha Bug, ES Identify, NAND Access
                                IOS247[53] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
                                IOS248[55] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
                                IOS249[56] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
                                IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
                                IOS251[58] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
                                IOS254 (rev 65281): BootMii
                                BC v6
                                MIOS v10
                                Report generated on 2012/02/26.
