Wii USB HD Loader
  • Yumraaj
    • 306
    #241
    Originally posted by Seasider
    I read somewhere, possibly earlier in this thread about avoiding using Seagate Drives, however I'm using a 400 gig Seagate Barracuda and its performimg like a dream !!
    I have a feeling that this issue is one of those that a drive that works ok for one persom may be troublesome for another , so basically it is a try it and see
    I would still advise people to avoid buying seagate drive just for wii games as it very temperamental. If it is Seagate with another name to it e.g Seagate Barracuda, this might work but I think seagate on its own might not work. At the end of the day it might be your luck as well but as I said try avoiding it if you can.
    • muckydevil
      • 12
      #242
      Yep Seagates are bad unless they are the ES ones. I've been running 5 1TB ES ones in my RAID server for a few years with no problems.
      Are there any good disk caddies that people can recommend, as I'll have to buy one and prefer not to fork out on a Western Digital My Book when a caddy would do?
      • yaas
        • Jun 2009
        • 188
        #243
        Hey,Yumraaj!Hope u better,mate!
        Just 1 question, I got games working on USB but not on disk & vice versa.
        The games that dont work on USB displays a blue screen with "error #002".
        Any idea as to why?
        Also, Ounch out was working on USB before, but it wont load now. Getting the same error message!
        Thanks.
        • Yumraaj
          • 306
          #244
          Any idea as to why?
          Thanks.
          Hi mate have you tried the latest revision mate? USB Loader GX (Official Theme Database) - Loader I'm sure in the setting there is an error 002 fix, set it to "ON", hopefully this will sort it.
          • clearwater
            has your Wii received an update recently?
            Which version are you on 4.0?
            • undercoverjamil
              • Apr 2009
              • 184
              #246
              Burn them onto disc & they should work great without crashing!
              Virtua Tennis is awesome.
              Will let you know abt Tiger Woods.
              i actually got the tiger woods from my uncle and virtua tennis from my dad and all i did was press the + button on my wiimote to rip them onto the usb.
              and before i got the games i tried downloading the games and putting them onto discs but they never worked. i always just got a black screen.
              • yaas
                • Jun 2009
                • 188
                #247
                Mate!You are a genius!
                IT WORRRKS!!!
                Thasnks.
                • Yumraaj
                  • 306
                  #248
                  Glad I could help.
                  • yaas
                    • Jun 2009
                    • 188
                    #249
                    Guys!I am trying to load games onto an internal Hitachi 80GB Hard Drive, but my PC won't pick up the drive.
                    When I stick it in my PC, it comes up as new device found but its not visible among the list of Hard Drives and the WBFS wont pick it up either.
                    I have put the drive in a USB enlosure.
                    Well, I use this drive in a Eurovox before.
                    Can someone help,please?
                    Thanks.
                    • Yumraaj
                      • 306
                      #250
                      Thanks.
                      Right click on my computer and select manage,
                      Select on disk management, you will see a list of drive connected to PC, if it is black, this means it hasn't been assigned a drive letter yet. Right click on the Black area and choose simple volume and follow the prompt to assign a drive letter and also to format it. Hope this help.
                      • yaas
                        • Jun 2009
                        • 188
                        #251
                        No joy,mate!Its not working.
                        The drive is there but it is showing as "unknown drive"!
                        I am losing hope!
                        • yaas
                          • Jun 2009
                          • 188
                          #252
                          Hey Yumraaj, can you please explain(in detail,plz) how to load & install new themes for the GXLoader!
                          I have tried different routes but just wont work.
                          I have downloaded all these themes from the GXLoader website but cant use them!
                          Hope you can help!
                          Thanks.
                          • Yumraaj
                            • 306
                            #253
                            Hope you can help!
                            Thanks.
                            Basically you should have:
                            1: The main application in the apps folder
                            2: config folder in the root of your SD
                            3: images folder in the root of your SD
                            4: theme folder in the root of your SD
                            OK, in the config folder you should have 2 folders which are backgroundmusic & language and you should also have 2 documents; GXGameSettings and GXGlobal.
                            images folder will have all your 3D covers and also your Disc art.
                            theme folder will contain your themes.
                            That's it.
                            • yaas
                              • Jun 2009
                              • 188
                              #254
                              That's it.
                              Thanks 4 that!
                              But I have an even bigger problem!
                              I cant get the GXLoader to load.
                              It loads without my USB plugged in but when I plug the USB & try to load it, I get a black screen with loads of numbers & stuff like "dump error" etc.
                              I need to fix that first to be able to put new themes on.
                              • Yumraaj
                                • 306
                                #255
                                Thanks 4 that!
                                You need to plug it in first then try to load it again. Normally it will do that if it cant see the drive. Try it again I'm sure it will be allright. Make sure you switch your Wii off first.
