Wii USB HD Loader
  • ajpepe72
    • Dec 2010
    • 14
    #541
    The wife wants to play X factor (honest)
    It loads fine from configurable usb loader but when you actually choose a song it says "please plug in usb microphone" even though mic is plugged into second usb slot.
    Any tips ?
    • ck-ok
      • 2592
      #542
      Any tips ?
      load game with ios 222 or 223
      • ajpepe72
        • Dec 2010
        • 14
        #543
        tried with 223-mload but still the same, and 222 it says is not installed.
        dont suppose you have a link for the ios i need ?
        • ck-ok
          • 2592
          #544
          here Digital Kaos - Downloads - hermes custom ios 222/223 installer
          • ajpepe72
            • Dec 2010
            • 14
            #545
            downloaded custom ios installer, navigated away from 249 to 223 and that installed fine, however 222 came up with a fail.
            tried launching the game with ios 222-mload and 223-mload but am still getting the "connect mic" message.
            • ck-ok
              • 2592
              #546
              bit of a age old problem this, try auto updating cfg loader
              can you run from disc to free up other usb port or buy a cheap multi usb connector and plug mic and hdd into same port
              • ajpepe72
                • Dec 2010
                • 14
                #547
                tried running from disk with neogamma with mic in usb slot 0 and same result, do i need to change iso in neogamma too ?
                Cant see auto update option in usbloader or am i just being dense ?
                • ck-ok
                  • 2592
                  #548
                  1.Start Configurable USB Loader and push 1 twice to get to the Global Options screen.
                  2.Select Search for updates and push right on the D-pad.
                  3.A selection of versions will come up. Choose the one you want to install and push A.
                  4.The new version will download and install over the currently running version.
                  Don't worry about meta.xml here, your changes will be preserved.
                  5.When complete, push any button to return to USB Loader.
                  6.Exit and restart the loader to try the new version.
                  dont think you can change ios in neogamma it just uses ios 249
                  what sort of mic is it?
                  • ajpepe72
                    • Dec 2010
                    • 14
                    #549
                    thanks, will give it a go later.
                    Mics are these : 5 in 1 Karaoke Mic Microphone White for Nintendo Wii on eBay (end time 12-Jan-11 10:30:02 GMT)
                    • ck-ok
                      • 2592
                      #550
                      try plugging them into pc and see if you get any signal from them
                      you could also try http://www.digital-kaos.co.uk/forums...taller-143444/ this can play dvd-rs and you can lauch them with different ios's
                      could be the mics ?8 sound pretty cheap for 2 mics
                      • ajpepe72
                        • Dec 2010
                        • 14
                        #551
                        Mics work fine in pc.
                        can i run uloader as well as having config usb loader or will i need to remove usb loader.
                        No, no joy with uloader either, tried 222 and 223. will have to try and borrow a proper mic to see if that works.
                        • ck-ok
                          • 2592
                          #552
                          you can use as many loaders as you want
                          • ck-ok
                            • 2592
                            #553
                            Originally posted by gonzalo42
                            finally!!!!!!!!!!!!!!
                            please dont use this its out of date try http://www.digital-kaos.co.uk/forums...taller-143444/ or a loader from here http://www.digital-kaos.co.uk/forums...oaders-183163/
                            • tripper
                              • 42
                              #554
                              if i use this do i have to have the home brew as well or just straight from my hard drive to my wii
                              tripper
                              • ck-ok
                                • 2592
                                #555
                                you dont need this if you use the 4.3 tut it has a usb loader in the download
