Wii USB HD Loader
  • Harrycz44
    #601
    Hello pleas where I find Homebrew Channel?? Must install or??? Thank you ( I am begginer about wii )
    • ck-ok
      • 2592
      #602
      depends on your system menu for 4.3 use Introducing: LetterBomb (the letter from heaven)
      for anything below use Bannerbomb - WiiBrew
      • Harrycz44
        #603
        Thank you mr. ck-ok.. Now I see on my TV screen Homebrew Channel.. Now I can use USB HDD with ISO files? Or must install any files pleas? How I can start iso from hdd pleas.....
        • ck-ok
          • 2592
          #604
          you need to do more than just install homebrew channel to play backups. try Digital Kaos - Downloads - modmii 4.3.4 choose wizard install. because you already have hb channel then you can skip that part of your custom tutorial.
          • Harrycz44
            #605
            Hello
            I must modmii 4.3.4 copy to sd card and start it with HB channel? sorry for my stupid question, I am really amater about this problematic.. o(
            • ck-ok
              • 2592
              #606
              Hello
              no modmii is a pc based program install it to your pc then run it and answer the questions it will ask you then it will download all your files and write you a tutorial to follow.
              • Harrycz44
                #607
                Hello I did few steps about hack wii.. I have installed HB channel, after I updated Ios 236 ( in my wii has ios58 ) after success apdate show everytimes ios58..??? I start USB loader gx2 and after load show only black screen... o((
                • ck-ok
                  • 2592
                  #608
                  thought you were going to follow modmii?
                  use this Digital Kaos - Downloads - sysCheck v2.1.0 Beta 11 to post us a syscheck .
                  • Harrycz44
                    #609
                    sysCheck v2.1.0b11 by Double_A and R2-D2199
                    ...runs on IOS58 (rev 6432).
                    Region: PAL
                    System Menu 4.3E (v514)
                    Homebrew Channel 1.0.0 running on IOS58
                    Hollywood v0x21
                    Console ID: 158575001
                    Boot2 v5
                    Found 70 titles.
                    Found 47 IOS on this console. 17 of them are stub.
                    IOS3 (rev 65280): Stub
                    IOS4 (rev 65280): Stub
                    IOS9 (rev 1290): No Patches
                    IOS10 (rev 768): Stub
                    IOS11 (rev 256): Stub
                    IOS12 (rev 782): No Patches
                    IOS13 (rev 1288): No Patches
                    IOS14 (rev 1288): No Patches
                    IOS15 (rev 1288): No Patches
                    IOS16 (rev 512): Stub
                    IOS17 (rev 1288): No Patches
                    IOS20 (rev 256): Stub
                    IOS21 (rev 1295): No Patches
                    IOS22 (rev 1550): No Patches
                    IOS28 (rev 2063): No Patches
                    IOS30 (rev 2816): Stub
                    IOS31 (rev 3864): No Patches
                    IOS33 (rev 3864): No Patches
                    IOS34 (rev 3864): No Patches
                    IOS35 (rev 3864): No Patches
                    IOS36 (rev 3864): No Patches
                    IOS37 (rev 5919): No Patches
                    IOS38 (rev 4380): No Patches
                    IOS40 (rev 3072): Stub
                    IOS41 (rev 3863): No Patches
                    IOS43 (rev 3863): No Patches
                    IOS45 (rev 3863): No Patches
                    IOS46 (rev 3863): No Patches
                    IOS48 (rev 4380): No Patches
                    IOS50 (rev 5120): Stub
                    IOS51 (rev 4864): Stub
                    IOS52 (rev 5888): Stub
                    IOS53 (rev 5919): No Patches
                    IOS55 (rev 5919): No Patches
                    IOS56 (rev 5918): No Patches
                    IOS57 (rev 6175): No Patches
                    IOS58 (rev 6432): USB 2.0
                    IOS60 (rev 6400): Stub
                    IOS61 (rev 5918): No Patches
                    IOS70 (rev 6912): Stub
                    IOS80 (rev 7200): No Patches
                    IOS222 (rev 65280): Stub
                    IOS223 (rev 65280): Stub
                    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug, ES Identify, NAND
                    IOS249 (rev 65280): Stub
                    IOS250 (rev 65280): Stub
                    IOS254 (rev 65281): BootMii
                    BC v6
                    MIOS v10
                    Report generated on 2012/04/04.
                    What is wrong pleas??
                    • ck-ok
                      • 2592
                      #610
                      Region: PAL
                      Hollywood v0x21
                      Boot2 v5
                      Found 70 titles.
                      BC v6
                      MIOS v10
                      except for the hb channel and ios36 everything
                      use Digital Kaos - Downloads - modmii 4.3.4 install it to your pc then run it choose wizard install and answer the questions you get asked then it will download your files and tutorial to a folder on your pc called copy to sd card when its done copy all the files in that folder to your sd card and put it in your console you can skip the hb channel install because you already have it then hack your wii
                      • Harrycz44
                        #611
                        I did it two times.. But I do not know what I must settings in modmii. Must downgrade to 4.1? ( in programm modmii is recommended )? Or can you prepare files ( for SD-card) correctly for me pleas????
                        • DeanCorp
                          • Apr 2012
                          Hey guys,
                          I have version 4.1, I have just turned my Wii on since 2010 and can't play any recent games. What updates do you suggest I do? I have WiiFlow installed.
                          • Harrycz44
                            #613
                            Originally posted by DeanCorp
                            Hey guys,
                            Maybe help you this https://sites.google.com/site/comple...fore-you-begin
                            • ck-ok
                              • 2592
                              #614
                              no need to downgrade
                              start modmii select wizard install
                              answer the questions it will ask you like how you want to play your backups, newer wiis cant play backups from disc but you can use usb/hdd.
                              hdd is by far the best root to go even if your console can play from disc.
                              ask it to download files to sd folder when its done open the folder on your computer and copy all the files in it and paste them onto your sd card and start modding skipping the part for hb channel as you already have it.
                              • Harrycz44
                                #615
                                ...runs on IOS58 (rev 6176).
                                Region: PAL
                                Priilaoder installed
                                Hollywood v0x21
                                Console ID: xxxxxxxxx
                                Boot2 v5
                                Found 74 titles.
                                Found 49 IOS on this console. 5 of them are stub.
                                IOS11 (rev 16174): Trucha Bug, NAND Access
                                IOS20 (rev 16174): Trucha Bug, NAND Access
                                IOS30 (rev 16174): Trucha Bug, NAND Access
                                IOS40 (rev 16174): Trucha Bug, NAND Access
                                IOS50 (rev 16174): Trucha Bug, NAND Access
                                IOS52 (rev 16174): Trucha Bug, NAND Access
                                IOS58 (rev 6176): USB 2.0
                                IOS60 (rev 16174): Trucha Bug, NAND Access
                                IOS70 (rev 16174): Trucha Bug, NAND Access
                                IOS80 (rev 16174): Trucha Bug, NAND Access
                                IOS202[60] (rev 65535 Info: v5.1): Trucha Bug, NAND Access, USB 2.0
                                IOS222[38] (rev 4 Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
                                IOS223[38] (rev 4 Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
                                IOS224[57] (rev 65535 Info: v5.1): Trucha Bug, NAND Access, USB 2.0
                                IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                                IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                                IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                                BC v6
                                MIOS v10
                                Report generated on 2012/04/05.
                                Second try o) It is better way?
