Hello pleas where I find Homebrew Channel?? Must install or??? Thank you ( I am begginer about wii )
Wii USB HD Loader
Harrycz44 -
depends on your system menu for 4.3 use Introducing: LetterBomb (the letter from heaven)
for anything below use Bannerbomb - WiiBrewsigpicComment
Harrycz44
Thank you mr. ck-ok.. Now I see on my TV screen Homebrew Channel.. Now I can use USB HDD with ISO files? Or must install any files pleas? How I can start iso from hdd pleas.....Comment
you need to do more than just install homebrew channel to play backups. try Digital Kaos - Downloads - modmii 4.3.4 choose wizard install. because you already have hb channel then you can skip that part of your custom tutorial.sigpicComment
Harrycz44
Helloyou need to do more than just install homebrew channel to play backups. try Digital Kaos - Downloads - modmii 4.3.4 choose wizard install. because you already have hb channel then you can skip that part of your custom tutorial.
I must modmii 4.3.4 copy to sd card and start it with HB channel? sorry for my stupid question, I am really amater about this problematic.. o(Comment
no modmii is a pc based program install it to your pc then run it and answer the questions it will ask you then it will download all your files and write you a tutorial to follow.sigpicComment
Harrycz44
Hello I did few steps about hack wii.. I have installed HB channel, after I updated Ios 236 ( in my wii has ios58 ) after success apdate show everytimes ios58..??? I start USB loader gx2 and after load show only black screen... o((Comment
thought you were going to follow modmii?
use this Digital Kaos - Downloads - sysCheck v2.1.0 Beta 11 to post us a syscheck .sigpicComment
Harrycz44
sysCheck v2.1.0b11 by Double_A and R2-D2199thought you were going to follow modmii?
...runs on IOS58 (rev 6432).
Region: PAL
System Menu 4.3E (v514)
Homebrew Channel 1.0.0 running on IOS58
Hollywood v0x21
Console ID: 158575001
Boot2 v5
Found 70 titles.
Found 47 IOS on this console. 17 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1290): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 782): No Patches
IOS13 (rev 1288): No Patches
IOS14 (rev 1288): No Patches
IOS15 (rev 1288): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1288): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1295): No Patches
IOS22 (rev 1550): No Patches
IOS28 (rev 2063): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3864): No Patches
IOS33 (rev 3864): No Patches
IOS34 (rev 3864): No Patches
IOS35 (rev 3864): No Patches
IOS36 (rev 3864): No Patches
IOS37 (rev 5919): No Patches
IOS38 (rev 4380): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3863): No Patches
IOS43 (rev 3863): No Patches
IOS45 (rev 3863): No Patches
IOS46 (rev 3863): No Patches
IOS48 (rev 4380): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5919): No Patches
IOS55 (rev 5919): No Patches
IOS56 (rev 5918): No Patches
IOS57 (rev 6175): No Patches
IOS58 (rev 6432): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5918): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 7200): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug, ES Identify, NAND
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/04/04.
What is wrong pleas??Comment
except for the hb channel and ios36 everythingsysCheck v2.1.0b11 by Double_A and R2-D2199
Region: PAL
Hollywood v0x21
Boot2 v5
Found 70 titles.
BC v6
MIOS v10
use Digital Kaos - Downloads - modmii 4.3.4 install it to your pc then run it choose wizard install and answer the questions you get asked then it will download your files and tutorial to a folder on your pc called copy to sd card when its done copy all the files in that folder to your sd card and put it in your console you can skip the hb channel install because you already have it then hack your wiisigpicComment
Harrycz44
I did it two times.. But I do not know what I must settings in modmii. Must downgrade to 4.1? ( in programm modmii is recommended )? Or can you prepare files ( for SD-card) correctly for me pleas????Comment
Harrycz44 -
no need to downgrade
start modmii select wizard install
answer the questions it will ask you like how you want to play your backups, newer wiis cant play backups from disc but you can use usb/hdd.
hdd is by far the best root to go even if your console can play from disc.
ask it to download files to sd folder when its done open the folder on your computer and copy all the files in it and paste them onto your sd card and start modding skipping the part for hb channel as you already have it.sigpicComment
Harrycz44
...runs on IOS58 (rev 6176).
Region: PAL
Priilaoder installed
Hollywood v0x21
Console ID: xxxxxxxxx
Boot2 v5
Found 74 titles.
Found 49 IOS on this console. 5 of them are stub.
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535 Info: v5.1): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4 Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4 Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535 Info: v5.1): Trucha Bug, NAND Access, USB 2.0
IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug, ES Identify, NAND Access
IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v10
Report generated on 2012/04/05.
Second try o) It is better way?Last edited by Guest; 5 April, 2012, 23:07.Comment
