Wii USB HD Loader
  • woggo22
    wii iso
    Hi, i have backed up all my games to iso files on my computer, how do i install iso files to my hard drive so i can play them on the wii?
      Format your hard drive using WBFS manager.Then it's just a matter of drag and drop
      • TheStretchedElf
        • 14
        #408
        Originally posted by DiddyDave
        --- INSTALLATION ---
        01. Download the ZIP file,
        Ok, done that.
        02. Extract the ZIP file to the root of your SD card.
        Yep, done that.
        03. You should now have two new folders, in your "apps" folder ("cIOS rev9" and "USB Loader 1_0").
        Er, does that mean I should create an "apps" folder and place those folders inside it?
        04. Launch the "cIOS Installer", from The Homebrew Channel.
        How do I do this? When I go to the Homebrew channel it's blank.
        • TheStretchedElf
          • 14
          #409
          Originally posted by TheStretchedElf
          Ok, done that.
          Yep, done that.
          Right, I finally figured out that you have to rename the .dol files to boot.dol so that homebrew recognises them.
          Unfortunately when I try to load cIOS36_rev9-Installer I get the error ret -2011.
          When asked, I am choosing WAD install (IOS36-64-v1042.wad in the root of the SD card) rather than Network install as I do not know how to connect my Wii to the internet.
          Also my Wii is Ver. 4.1E.
          PLEASE PLEASE HELP!
          • MagicToes
            • 5
            #410
            This is doing my nut in!! I've succesfully partitioned my external HDD and put wii USB HD Loader on the sd card and got that part sorted....now I'm having troubles trying to use WBFS to add iso to the HDD as (a) my pc won't see the wii formated side, and (b) WBFS comes up with a message in the CMD prompt 'C:/documents is not recognised as an internal or external command, operable programe or batch file'
            anyone have any ideas whereI'm going wrong please? Can you tell I'm a newbie
            Update - horrah!! realised that maybe I'd d/l the incorrect goodies...what I had d/l wasn't the WBFS Manager but something similiar have d/l correct WBFS Manager and fingers crossed should be ok now...yet to test results!
            • bwc632
              only game i cant get to run is wii sports resort so far...... anyone else having diffuculty with a game?
              • armstrong14
                #412
                Does this app run on version 4.2e??
                • gamester05
                  • 15
                  #413
                  Hi guys need help i cant get this to work i put it in to the apps folder on my mem card but when i go to home brew channel it is not there tried it on the root as well but cant find it well confused, any help please
                  • soulrespect
                    #414
                    Fantastic site!!!!! i'm a newbie just trying to get USB Wii loader and found this site. Not just for wii but everything i seem to be interested in. I am a self confessed gadget freak. Think i will be spending alot of time here.
                    • soulrespect
                      #415
                      Is there anyway of installing USB Loader without a D Pad
                      • TobyTyke
                        Super Mario Green Screen
                        Whenever I try and run New Super mario via USB loader I just get a green screen, I then have to power-cycle then wii before I can use it again. Is this normal or is there anything which I can do to correct this.
                        any help would be greatful
                        • giam_qa
                          3.4e WII [Ita]
                          The WII of my Son is ver 3.4e this proceture will be compatible?
                          Thank you in advance.
                          Ciao
                          • soulrespect
                            #418
                            Please Help!!!
                            05. When it asks you the type of installation you want to use, press Right, on the D-Pad, and select "Network Installation."
                            Does this mean that i need a D Pad to install this. Can it not be done with normal controller. I try to install via HBC but i cant click on SD card. Please Help
                            Many Thanks in advance.
                            • dreadz
                              What usb hardrive do you need to use.
                              sorry im a complete NooB.
                              Many Thanks
                              Dreadz
                              • bobtracy
                                • 14
                                #420
                                having trouble with usb hd loader i want to have it as a channel ? its showing up as a channel but when i start it screen just goes green blank? am i doing somthing wrong? any ideas anyone?
