Wii USB HD Loader
  • ck-ok
    • 2592
    #511
    Originally posted by wiineuling
    Hello
    my wii iss behind a firewall, proxyserver and passauth, so i have no network connection to the www. is there a posibility to install all from SD?
    your forst post should be in the introduction section.
    install all what from sd?
    • ajpepe72
      • Dec 2010
      • 14
      #512
      I have used the guide right at the beginning of this thread and have installed everything (usbloader1.0) ive configured my usb drive and it shows up in usbloader so all good there.
      I loaded a iso file from my pc onto the drive using Wbfsmanager and the game shows up in usbloader but when i go to load game it shows a bright blue screen which says "Error #002,press the eject button,remove disk and turn off power to the console"
      Any ideas ?
      • ck-ok
        • 2592
        #513
        Any ideas ?
        yes go into settings and switch on 002 error fix
        • ajpepe72
          • Dec 2010
          • 14
          #514
          Where is settings found, cannot find any settings button in uloader ?
          • ck-ok
            • 2592
            #515
            usbloader or uloader?
            • ajpepe72
              • Dec 2010
              • 14
              #516
              Nothing in uloader ver 1.0, is it worth upgrading it to the newest version ? any idea what the newest version is?
              • ck-ok
                • 2592
                #517
                no not really i would take it off sd card and use this Configurable USB Loader - GBAtemp.net
                • ajpepe72
                  • Dec 2010
                  • 14
                  #518
                  Will give that a go, thanks.
                  The link above takes you to a page, is it just the cfb usb loader i need to put on my sd card or the other .dol and zip files to ?
                  Thanks in advance.
                  Edit: Installed config usb loader and the game that is on the usb hard drive loaded straight up, thanks a lot, really appreciate your help .
                  • ck-ok
                    • 2592
                    #519
                    Thanks in advance.
                    download cfg usb loader 62 zip
                    extract file and open insdroot folder and put usb folder in the root of sd card then open apps folder and put usb folder in your apps folder
                    • cesarst
                      • Dec 2010
                      USB HD Loader
                      Can ISOs be loaded into the HDD from previous backups?
                      Originally posted by DiddyDave
                      Hi here is what we have been all waiting for the USB HD Loader. The best thing since sliced bread. This will let you load all your backups from a USB HD so no more DVD's. This app is confirmed working.
                      Here is what you need to download
                      Digital Kaos - Downloads - USB HD Loader
                      Digital Kaos - Downloads - cIOS36_rev9-Installer
                      And for those that like the Channels in stead of loading via the homebrew channel
                      Digital Kaos - Downloads - Wii USB HD Loader Channel
                      Here is an update on this app as i'm sure there will be people unsure on how to set this app up.
                      --- INSTALLATION ---
                      01. Download the ZIP file,
                      02. Extract the ZIP file to the root of your SD card.
                      03. You should now have two new folders, in your "apps" folder ("cIOS rev9" and "USB Loader 1_0").
                      04. Launch the "cIOS Installer", from The Homebrew Channel.
                      05. When it asks you the type of installation you want to use, press Right, on the D-Pad, and select "Network Installation."
                      06. Watch carefully, to be sure everything installs successfully. If you encounter any errors, rerun the "cIOS Installer", until it installs correctly.
                      07. Reboot.
                      08. Plug in your chosen USB drive. If your drive has a power light, be sure that it is correctly powered on.
                      09. Reboot.
                      10. Launch the "USB Loader", from The Homebrew Channel.
                      11. If the USB Loader launches, and the black rectangular section contains no text, you will need to power cycle your Wii, using the console power button.
                      12. If you receive "ERROR: Could not initialize USB subsystem (ret = -1)", then your USB device is NOT supported!
                      13. If you receive a WARNING that no WBFS partitions are found, your drive IS supported!
                      14. Press the "A" button, to format a partition. (WARNING:: Formatting a partition will delete EVERYTHING from that partition. Be sure to backup any important data, BEFORE pressing "A".)
                      15. The next screen will allow you to choose the partition you wish to format. Select the partition, and press "A".
                      16. After formatting is complete, you will be presented with a games list (currently blank). The screen will also show the amount of used space, and the free space remaining (There is currently a small bug, in the free and used space listings. The correct size is not shown, but it still can be used.)
                      17. Insert a Wii game disc you wish to backup.
                      18. Press the "+" button, to backup the disc. (Depending on the game, a disc can take anywhere from 30 seconds to 45 minutes to backup. Example: Carnival Games only took 58 seconds!)
                      19. Once the backup process has completed, press any button, to return to the game selection screen.
                      20. Eject your game disc.
                      21. Select your game from the game list, and press "A".
                      22. Your game should load, and be fully playable, from the USB device!!
                      NOTE: Some games will backup successfully, however will still require the disc to be inserted during gameplay (This appears to be another bug).
                      • ck-ok
                        • 2592
                        #521
                        why bother this tut is out of date use wiiflow/cfgloader or usb loader gx these are much more up to date.
                        • ajpepe72
                          • Dec 2010
                          • 14
                          #522
                          CK-OK,
                          Everything is working fine now, what i'm trying to do now is install a channel to launch the usbloader instead of going through HBC. Ive followed the guide in the link below up to the point where it says to run the "Instforwarder" app in homebrew and then select ios236, however ios236 is not showing when I scroll through the different IOS's ?
                          • ck-ok
                            • 2592
                            #523
                            CK-OK,
                            Forwarder - GAF's Wii Homebrew Tutorial
                            no need for that go to the link i gave you for cfg loader click on other useful download link and there is a forwarder link, download the wad put it in wad folder and install with wad manager
                            • ajpepe72
                              • Dec 2010
                              • 14
                              #524
                              Ok, downloaded the wad file, placed it in the wad folder.
                              then fired up homebrew and the wadmanager and chose iso58 then sdcard, clicked on the file "USBLoaderCFG - UCXF - IOS58 v6.wad" to install and its coming up with :
                              installing ticket...error! (ret = -2011)
                              So close yet so far !
                              • ck-ok
                                • 2592
                                #525
                                fire up wad manager select ios249 or ios36 then sd card then select wad 58
