USB Loaders do not detect my USB Flashdrive.
  • Keithuk
    • Aug 2010
    • 2264
    #31
    Its keys.bin and nand.bin that are the main NAND backup the bootmii folder is so you can access the bootmii as you exit HomeBrew to save and restore the backup.
    Well I've no idea why you can't install the missing IOS's. IOS220, IOS223, IOS224 are the main ones you need to install plus all 7 dx2 v8.0 IOS's.
    Keith
    2010 Golf GTD (170)
    • Gaengphed
      • Sep 2014
      • 13
      #32
      Hi Keith,
      It worked for me using this tut: How to install cios222 on Wii 4.3|Play Backup Games|[Best Tutorial] - YouTube ! Installed the IOS36 then run cIOS222 installer and point it to the 236 'slot' ( or'stub' ?) then installed it. Now USB Loader GX works fine. I also found a hint putting the USB drive in the left USB slot instead of the right. The drive that I have is an older 160Gb drive. Worked immediately! Kid is now playing Rabbit something... ;-)
      Thanks for your patience and hopefully other might find the video helpful :-)
      • Keithuk
        • Aug 2010
        • 2264
        #33
        Well I thought you would have know which USB port to use the one nearest the edge, its been talked about many times on here. Post another sysCheck so I can see everything needed is installed?
        Keith
        2010 Golf GTD (170)
        • Gaengphed
          • Sep 2014
          • 13
          #34
          Hi Keith,
          Just did a SysCheck, it now reads the following:
          sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
          ...runs on IOS58 (rev 6176).
          Region: PAL
          System Menu 4.3E (v514)
          Priiloader installed
          Drive date: 2007.02.13
          Homebrew Channel 1.1.2 running on IOS58
          HomebrewFilter ist nicht installiert
          Hollywood v0x11
          Console ID: 109041811
          Boot2 v4
          Found 102 titles.
          Found 47 IOS on this console. 15 of them are stub.
          IOS4 (rev 65280): Stub
          IOS9 (rev 1034): No Patches
          IOS10 (rev 768): Stub
          IOS11 (rev 256): Stub
          IOS12 (rev 526): No Patches
          IOS13 (rev 1032): No Patches
          IOS14 (rev 1032): No Patches
          IOS15 (rev 1032): No Patches
          IOS16 (rev 512): Stub
          IOS17 (rev 1032): No Patches
          IOS20 (rev 256): Stub
          IOS21 (rev 1039): No Patches
          IOS22 (rev 1294): No Patches
          IOS28 (rev 1807): No Patches
          IOS30 (rev 2816): Stub
          IOS31 (rev 3608): No Patches
          IOS33 (rev 3608): No Patches
          IOS34 (rev 3608): No Patches
          IOS35 (rev 3608): No Patches
          IOS36 (rev 3608): No Patches
          IOS37 (rev 5663): No Patches
          IOS38 (rev 4124): No Patches
          IOS40 (rev 3072): Stub
          IOS41 (rev 3607): No Patches
          IOS43 (rev 3607): No Patches
          IOS45 (rev 3607): No Patches
          IOS46 (rev 3607): No Patches
          IOS48 (rev 4124): No Patches
          IOS50 (rev 5120): Stub
          IOS51 (rev 4864): Stub
          IOS52 (rev 5888): Stub
          IOS53 (rev 5663): No Patches
          IOS55 (rev 5663): No Patches
          IOS56 (rev 5662): No Patches
          IOS57 (rev 5919): No Patches
          IOS58 (rev 6176): USB 2.0
          IOS60 (rev 6400): Stub
          IOS61 (rev 5662): No Patches
          IOS62 (rev 6430): No Patches
          IOS70 (rev 6912): Stub
          IOS80 (rev 6944): No Patches
          IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
          IOS223 (rev 65280): Stub
          IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
          IOS249 (rev 65280): Stub
          IOS250 (rev 65280): Stub
          IOS254 (rev 65281): BootMii
          BC v6
          MIOS v10
          Report generated on 2014/09/27.
          I've run some games and not all of them are working, yet the most are. So it could be that I still need to install another IOS or cIOS. But I guess your knowledge succeeds mine in this ;-) Thanks for taking a look at the syscheck.
          Have a good weekend.
          Gaengphed.
          • Keithuk
            • Aug 2010
            • 2264
            #35
            Well you've only remove 1 IOS that's Stub. If you can't follow simple instructions on what's needed then sorry but you need find another forum to help you, as it feels like I'm just banging my head against a wall. I've softmodded 15 Wii's over the past few years all in the same way after I found out what was needed on my own Wii and they all work perfectly.
            Keith
            2010 Golf GTD (170)
            • Gaengphed
              • Sep 2014
              • 13
              #36
              Exactly, 1 stub removed taken from a youtube-entry. I need proper wad-files that my Wii accepts ;-)
              Sorry banging your head ;-)
