i tried to do this on an other tutorial and it didnt work but il try this one fingers crossed
Wii softmod for Dummies(without zelda)
This topic is closed.
works
works finethis soft mod uses the bannerbomb crack read the pdf file and follow the instructions and all should be fine. I have not tested this on version 4 but feedback would be welcome. Print out the pdf. file before you do anything read it twice and follow the instructions precisely step by step.Comment
Hey,Hey Moregeld,
I seem to be having the same problem. Yumraaj kindly provided with with a workaround (See permalink/post # 243 in "Wii USB HD Loader" topic), but when installing the Wad Manager I get the same error.
Can you maybe put some together like Yumraaj (ie. a copy of your SD card contents & steps to execute)?
That would be much appreciated!
If you PM Lercetia, he might be able to prepare one for you.
He did the same to me.
I have removed all the files of the memory stick - and placed them somewhere on the PC - Or I can PM you with the websites that I got the files from.
Quote, it was a risky job without bricking the Wii. But I was in luck that never happend.
Let me know,
MGComment
has anyone managed to get a disc loader that will play the new games my sims racing for one,
and if you know of one that will load this game on dvd not usb
1. what is it
2. how do you load it on to your wii
3. im an idiot so please someone give me step by step instructions
4. im an idiot
many thanksComment
Orite mate cheers for this although I can't download it as it's not letting me, think it is just due to me being new so I will try later.
Edit: Letting me now, think I just needed to post first.
Also just one question...
Do you need to keep the SD card in the wii once you have installed everything etc.?Last edited by CraigyRFC; 3 July, 2009, 11:50.Comment
No just install whats on the card remove the card when your done thenOrite mate cheers for this although I can't download it as it's not letting me, think it is just due to me being new so I will try later.
Do you need to keep the SD card in the wii once you have installed everything etc.?Comment
Using disc loader
I have a major problem. Everything installed fine onto my wii, but when trying to play an iso that i have burnt onto dvd+using imgburn it will just not load using the disc loader channel or the loader that i have downloaded on the homebrew channel. Just a blank black screen. really winding me up any help appreciated.
Thanks in advanceComment
