Wii 4.2E softmod tutorial. Easy to follow guide.
  • gareth626
    • Feb 2010
    • 18
    #376
    hello
    i have followed everything on method A
    installed everything with no problems
    i am just lost on how to play copied games on the wii ???
    i have burned an iso of a game
    [Wii] Wii Play (PAL) (Scrubbed) Torrent - btjunkie <<< link to the game i downloaded to try out
    the iso was compress and i used imgburn and wrote it to a DVD-R disk that holds 4.7GB
    i then inserted the disk and tried running on homebrew channel with uloader but it says ERROR: USB Device disconnected then i press 2 for dvd mode and i get dvd error -2 ????
    then i tired on neogamma and clicked launch game on dvd then it says launching game ... then gives me a dvd read error (1048)
    i understand i could be doing something completely wrong ???
    please help
    • ck-ok
      • 2592
      #377
      Originally posted by gareth626
      hello
      please help
      did you unrar the iso before burning?also if you have a new wii you may not be able to play back up discs because of the new chip that cant be hacked,try fomatting a usb thumb drive to fat 32 and put the iso on that ,then try playing again.
      • gareth626
        • Feb 2010
        • 18
        #378
        yea i did unrar the file ... i do have the new black nintendo wii ... how do i format the usb thumb drive to fat32 ? i burned the iso to a dvd-r disk
        am i doing this right ?
        burn iso onto disk with imgburn
        insert disk to wii
        whilst sd card is in wii, open homebrew channel
        open neogamma and run dvd ?
        should that make the game work ?
        • delboy71
          • 122
          #379
          insert disk to wii
          Hi, the new black wii cant play dvd back up games due to the dvd drive. The only way you can play back ups on a black wii is to run them of a external hdd or a large pen drive.
          • ck-ok
            • 2592
            #380
            insert disk to wii
            if you have a black wii you can't play backup discs,to format your usb thumb put it in computer right click on drive and pick format fat 32
            • gareth626
              • Feb 2010
              • 18
              #381
              ok
              i have a 250gb external hard drive that i currently have plugged into my pc ... so your telling me that if i download a game from btjunkie for example and unrar it on the external hard drive ... i just plug the hard drive into the usb on the nintendo and run ???? and i will b looking for the iso i unrared yes ???????
              • delboy71
                • 122
                #382
                ok
                this is the guide how to do it from hdd HOWTO: WBFS Manager for Windows basics. Ade&#039;s Softmodding Wii blog
                • gareth626
                  • Feb 2010
                  • 18
                  #383
                  how do i get dvds to work on my wii ? can i not do this as it cannot read disks ?
                  • delboy71
                    • 122
                    #384
                    nintendo have done something to the newer wii's that makes them not read back up dvd's,something to do with the chip in the actual dvd drive so im afraid its the hdd method only for you.
                    • gareth626
                      • Feb 2010
                      • 18
                      #385
                      can i use the hdd to play movies ??
                      and i am going to get a new 16gb usb pen or do i need a hard drive
                      • ck-ok
                        • 2592
                        #386
                        you can play movies off hdd or usb pen with mplayer-ce,look in wii download section iv'e uploaded all the apps on there.
                        good luck
                        • oji1
                          • 7
                          #387
                          uloader 4.1 update
                          Having two problems.
                          1. When I try to do the uloader update (online) either download uloader or alternative I get error update.txt not found.
                          How do I fix this?
                          2. Also I am finding when trying to select games on uloader my hand is not always visable.
                          Why is this?
                          Thanks for any help sorting.
                          • gareth626
                            • Feb 2010
                            • 18
                            #388
                            good luck
                            i cant find this section....
                            cud you send me a link ?
                            • ck-ok
                              • 2592
                              #389
                              try this Digital Kaos - Downloads - Wii
                              • ck-ok
                                • 2592
                                #390
                                How do I fix this?
                                Why is this?
                                dont know sounds like you have a missing file,try swapping this http://www.digital-kaos.co.uk/forums...-1-pack-89896/ with the one in your apps folder
