just a link to a bargain external that im told works well with wii ?39.99 for 500gb with 10% off ordered online cant even find one from china that cheep on ebay! Buy IOMEGA SELECT 500GB 3.5 EXTERNAL HARD DRIVE | 500gb 3.5 external hard drive - advice | Comet
Wii 4.2E softmod tutorial. Easy to follow guide.
PLEASE HELP. i installed boot.elf no problem and once in homebrew everyhting was going fine till step 6 of method a. so i did as instructed and started with method b. when it comes to removing ios 222,223 etc none of those wads were present (infact ios257 is the only 3 digit wad i have).so when i go into wad manager to install them they show as empty wads and i get error! (ret = -1). i have reformatted my sd card with no change of results and even tried to load them via a usb storage device. ios07-64-v6687 wad is the only one that loads (and shows a size of 1.07mb, all the others show 0.0mb). pls help me here as when i open uloader it gives me a fault msg ios222 and ios223 required and then quits.
EDIT
k i found the problem. macbook pro shows wad files as unzipped but they are actually still compressed. downloaded zip file onto pc and unzipped to usb and installed the wads no problem!!
unfortunately now i get ERROR usb device disconnected in uloader. have tried unplugging both usb and sd card and reconnecting but no results.Comment
I read somewhere that Mario and Sonic at the winter olympics can brick your Wii if you don?t patch it with Brickblocker. Could that happen with this softmod? If so what games needs to be patched?
I will only use USB HDD and no network, could it happen anyway?Comment
i patch all games only takes 10 seconds,if you have preloader installed updates should not be a problem.but why take the risk for a 10 second patchsigpicComment
hi all
first post (so be gentle)
ran this soft mod last night all went perfect I think
just a couple of questions
do i have to leave the sd card in ?
is it right that i can now play dvds on my wii (if so how)
many thanks for the idiots guide (i really needed it
hi you need mplayer ce 0.75 put that in apps folder and run through homebrew channel.MPlayer CE cIOS Installer put that in apps folder run through hb channel , internet connection needed for this.MPlayer CE Forwarder channel put in wad folder and install with wad manager,and you should be up and running,all files are posted in wii downloads good luck sd card i always leave mine in.sigpicComment
Still thinking of doing this on my sisters new black wii
Got the files off banerbomb ready to go on the sd card
Just a slight query, the guide says to follow the bannerbomb instructions then go to to ades blog ades blog then says I need the following installed
HOWTO: Install The Homebrew Channel, DVDx and Bootmii Ade's Softmodding Wii blog
dvdx and bootmii and to download some more packs
Just wanna clear that up first really....if this makes no sense .....apologies...aint tried the process as yet
Thanks for any adviceComment
