Use this, no need to update to 4.2, 4.1 will do everything you want.
4.1 to 4.2 softmod
Update Wii firmware from 4.1E to 4.2E
Thanks Reddevil157. Tried to update using your post. Updated Wii successfully - however, when launching games using cfg games starts to load then freezes up at point at whcih it displays messages on how to hold wiimote. The games then do not load any further.
Any ideads as to what may have gone wrong?
Thanks.Comment
if it happens on all games ?... try updating your cIOS to rev 20, there's a wad in the d/l section by happyhighlander, just put it in the wad folder and install with wad manager, it just over writes the existing one.sigpicComment
i have the same problem. I have 4.1 and need to upgrade to 4.2 coz there are games that would not run.why not use this Digital Kaos - Downloads - v4.2 safe firmware updater it will do it all for you
good luck
i hope i am doing this correctly.Comment
I would think it will depend on how old your Wii is on the earlier ones you can burn Zumba to a DVD and play it through NeoGamma. I play Zumba on my 4.3E of the HDD.Keith
2010 Golf GTD (170)Comment
My wii was purchsed February 2008 I recently hacked with the Bathaxx it downgraded my system from 4.3 to 4.1. I tried to run from HDD but when it gets all the way up to loading the actualy game sequence ( I can run the game add my players name) but after that the system reboots. Is this a IOS, Firmware incompatability issue?Comment
try installing Digital Kaos - Downloads - priiloader v0.7 if you dont already have it and block disc and online updates.My wii was purchsed February 2008 I recently hacked with the Bathaxx it downgraded my system from 4.3 to 4.1. I tried to run from HDD but when it gets all the way up to loading the actualy game sequence ( I can run the game add my players name) but after that the system reboots. Is this a IOS, Firmware incompatability issue?sigpicComment
hi i got errors while updating my wii 4.1u to this update ,it says ''ES_AddContentStart(0000000100000046, 0) failed -1017''
install returned -1
installation complete!
Something failed. Sorry.
There was an error.
Continue with other installation? (it is not recommended)
press A to confirm press B to deny.......
i try to press iether A and B since i reintall it again the process . i do unplug the wii but still the same errors...
pls. help me with this i need to update my wii to 4.2u so i can used the neogamma to paly burn disk w/c i already tried on 4.1u but it failed my almost forever.. very much appreciated for the help...godbless.!Comment
Welcome to DK.
If you only want to update to 4.2 to play burnt games with NeoGamma this will depend if your CD drive is old enough so please post a sysCheckb19 as instructed in that link. Playing burnt games isn't really an economical process today. You may as well install USB Loaders and play games of a USD hard drive. This will save storing all your games on DVD's and saving them somewhere.
If your CD drive is old enough you should be able to play burnt games with NeoGamma providing you have the correct IOS's installed.Keith
