I had a 4.2 system, soft modded. Then sister did update to 4.3. Since then i re-modded the wii and have the homebrew channel. Every time i go to re-add neogamma it wont work, i get a 1252 or something similar error. Will this version help with that ? I've been trying with R9.
neogamma r8 final
i take it you have fully modded the wii?I had a 4.2 system, soft modded. Then sister did update to 4.3. Since then i re-modded the wii and have the homebrew channel. Every time i go to re-add neogamma it wont work, i get a 1252 or something similar error. Will this version help with that ? I've been trying with R9.
which tut did you follow?
could be a problem with the lens but we need more infosigpicComment
Gonna give this a try tonight, just come back to the Wii after a year and things have changed....Comment
Help me please with a channel for playing backup discs
I have a 3.4e wii which already has the homebrew channel, however it won't play all the latest games. I am fairly new at this sort of stuff and would really appreciate advice on how/where to get a channel to play backup discs?Comment
download neogamma from the first post of this thread, that will give you a backup launcher.
then install Digital Kaos - Downloads - cios38 rev17sigpicComment
Thanks a lot -works well with really easy instructions. What can I do so that I can open the games directly through a channel rather than via the HBC each time?Comment
try downloading the forwarder wad from NeoGamma-Forwarder-NGFW.rar and install it with wad managersigpicComment
Keith
2010 Golf GTD (170)Comment
tryin it
gonna try it, got a issue with 4.3u issue not reading DVD-R but have another one sitting next to it that will, looks like it may be a chip issue but will tryComment
It depends if you bought your Wii with 4.3U installed as the 4.3's have a different DVD drive D3-2 that won't read burnt DVD's. I've tried burnt games in mine and it come back with a USB read error 1167.
Wii Black 4.2E Neogamma Error 1167
Update:
If you want to check if your Wii has the modified DVD drive type in your Wii number in Wii Drive ChipKeith
tripper
