dvd drive version wont play backups
  • roryson
    • Mar 2009
    • 694
    #31
    HBC didnt recognise preloader on my sd card. any ideas?
    • ck-ok
      • 2592
      #32
      make sure preloaders in the apps folder and also make sure the preloader folder is not inside another folder
      • roryson
        • Mar 2009
        • 694
        #33
        its not, i'll try the priiloader..
        • roryson
          • Mar 2009
          • 694
          #34
          got priiloader showing up on HBC
          • roryson
            • Mar 2009
            • 694
            #35
            with the hacks.ini file do u rename it to hacks or as it came OLD-4.1-4.2-hacks...?
            • ck-ok
              • 2592
              #36
              if your using priiloader have you got the hacks from dogtoffees guide?
              • ck-ok
                • 2592
                #37
                the hacks should just bee called hacks.ini and placed in root of sd card not in a folder
                • roryson
                  • Mar 2009
                  • 694
                  #38
                  i used the hacks u gave
                  • roryson
                    • Mar 2009
                    • 694
                    #39
                    im using the dogcoffe guide. do i need the hacks from there?
                    • ck-ok
                      • 2592
                      #40
                      are they working?
                      • roryson
                        • Mar 2009
                        • 694
                        #41
                        not tried it yet, the guide says i need IOS70-patched.wad installed
                        • ck-ok
                          • 2592
                          #42
                          how far have you got with the 4.2 tut?
                          • roryson
                            • Mar 2009
                            • 694
                            #43
                            u mean the complete 4.2 tutorial? if so i did it all
                            • ck-ok
                              • 2592
                              #44
                              then you have a patched ios 70 installed
                              • roryson
                                • Mar 2009
                                • 694
                                #45
                                i've put priiloader on my sd card and its come up on HBC and installed it right i think, but after that i cant find the priiloader menu.. any ideas m8?
