well you cant do the mod go and rent 1 of the games you only need it for the mod
4.3 mod
Still have HBC installed after updating to 4.3, use only II mod part
Hi, ppl.
I had the HBC installed and updated to the last version, and today i updated from 4.2 to 4.3, HBC still there, i was using the 4.2 tutorial to softmod, but only installed HBC, Bootmii and made a NAND BK, so my question is can i use the second part of the mod to continue, or should i still use the 4.2?
Thanxs in advance..
GP[PT]
...Wii/PS2...Comment
HELP!!!
Ok, here's my problem. I can"t get HBC to load. From Wii or Bootmii all I get is a black screen. Here's what happend... I had 3.2u and all was good. I played GH6 (PAL ver.) using USB loader. Game froze about an hour in requiring a hard reset. After that HBC would not load. I tried deleting and reinstalling using the old Twilight hack. Seemed to install ok, but still no HBC. Unfortunately, I never made a nand backup (dumb-ass!). Reluctantly I updated (to 4.3u) thinking it would remove all mods and I'd have a clean slate to reinstall. Found your forum, dl'ed your hack pack, and got HBC, Bootmii installed (as boot2). Booted back to Wii...and still no HBC. The screen just goes black and I have to hard reset. I did the nand backup from Bootmii since HBC would not load. I'm lost now. Any help would be GREATLY appreciated. Thank you in advance.Last edited by driven7398; 1 October, 2010, 22:08.Comment
you need to follow 4.3 tutHi, ppl.
Thanxs in advance..
GP[PT]
...Wii/PS2...sigpicComment
The Wii I am going to mod was purchased secondhand and has a lot of the previous owners info ..(saves etc) which I would like to remove & start from fresh before I mod it.
Is the below good advice to start me on my way ? ....
"Factory reset? "
Go into the system options and find Format Wii System Memory (Wii options, last selection on last page) occording to the manual that will wipe all data from the Wii's internal memory. Not sure if thats a true factory reset, not sure if it will act like when the box is open and prompts you for settings, but all game data will be erased .
After that was done I was going to use the 4.3e mod tut from this thread & start from there.
Anything else I should know before starting? ....sigpicComment
all the reset will do is clear saved games and other uselesss dataThe Wii I am going to mod was purchased secondhand and has a lot of the previous owners info ..(saves etc) which I would like to remove & start from fresh before I mod it.
"Factory reset? "
Just a note...oops so youv'e updated to 4.3 and you want to remod your wii or mod it for the first time then follow this tut for 4.3e/u
first your gonna need to install homebrew channel to do that you will need one of these games Indiana Jones Original Adventures(ntsc-u/pal) -4.3u/e
or
Super Smash Bros Brawl(ntsc-u) -4.3u
format sd card to fat 32
Use a standard SD-Card, 2g or less
download the hack from here Digital Kaos - Downloads - 4.3 hack files and unzip Hackmii_0.8_IP_SS_BB2.zip, and put on sd card
then follow this if you using indiana jones
Works with 4.3u/e
-Play Lego Indiana Jones Original. Start a new game and complete level one with the nunchuk attached then make a saved game, then exit to System Menu.
-Go to wii settings, data management, save games, wii, SD
Delete the Lego Indiana Jones Save Game.
-Click SD, copy Indiana PWNS for your region
-Play Lego Indiana Jones original without the nunchuk attached load save game slot 1
When the game loads, you will be in Barnett College. Walk to the Art Room (through the Courtyard), approach the left character on the podium. When it zooms on him, choose the switch to option (two silhouettes, staggered, with an arrow pointing between them).
this will start hackmii installer.
if your using super smash brothers brawl then do this.
Smash Stack - Works with 4.3u
-Load SSBB ntsc, with sd-card removed, make a save file if asked
-Go to the stage builder, delete all custom stages found, exit the stage builder
-Exit all the way back to the main SSBB menu
-Insert SD-CARD, Go back to the stage builder
-HackMii Installer loads
now you can install homebrew channel and bootmii
Read the Scam warning and press 1
It may take a minute or two for the "press 1" to appear- be patient
Install the HomeBrew Channel
Install Bootmii as Boot2(boot2 may not be available, IOS installs automatically)
Prepare the SD-card
now you need to do a nand backup
Load HBC, press -HOME-, launch Bootmii
Make a nand backup
Press Power, Power, Power, Reset, Reset (or use gc-controller)
Power = Right, Eject = Left, Reset = Select
this thread willhelpif you need more info http://www.digital-kaos.co.uk/forums...loader-109168/
make sure you save these to your pc for safe keeping
nand.bin
bootmii
keys.bin
format sd card again and extract modpack from the folder you downloaded earlier to sd card
run md5summer.exe and click verify sums and check theres no errors
now you need to install your wads.
Start HBC, press [HOME], Launch Bootmii
Multi-Mod Manager Starts (via cboot2)
Never Uninstall IOS, you will brick your wii
Select "WAD Manager" - Press A
Press (1) to "Install all Wads" - Press A
19 wads should install without issue
"Press any button to continue"
Be sure all the wads install, very important
If the wads fail to install, install 1 at a time
Press B two times- main menu
thats it nearly finished just need to install priiloader
You should now be at the main menu of Multi-Mod Manager
Select "App Manager" -press A
Select priiloader -press A
Read the warning- Press +/A to install -if needed Hold B press +/A to install with cIOS
After priiloader installs, it may freeze during restart- this is ok
Hold reset and boot wii while holding reset- priiloader will load
Select "System Menu Hacks"- Press A
Enable "Block Disk Updates", and "Block Online Updates", others if you like
If MMM loads at boot, select Manage Priiloader, Edit Priiloader Hacks, enable needed hacks.
If you don't know what the hack does- you don't need it.
Your wii should now block Disk updates and online updates
Note: Prilloader installer gives two errors-
/loader.ini couldn't delete error -106
/password.txt couldn't delete error -106
this is not a problem just carry on
thats it done
You say up the top to browse to the SD card and delete the indy saved game file... That shoud read WII not SD...
Great instructions though...Comment
You should mention that you need to register with all these sites to download the necessary files for us newbies out there.Comment
all these sites, you mean this one as all the files are hosted here,and posted for the use of dk members,any non members only have to make one post before they can download,seems reasonable to me.Last edited by ck-ok; 23 October, 2010, 22:46.sigpicComment
Eventually took the plunge, and the Wii is now updated - thanks for the walkthrough! One thing I have noted is that games from the HDD which are NTSC are only in black and white - is there any setting I have overlooked to change this, PAL ones are in colour.sigpicComment
