4.3 mod
  • Bones77
    • Nov 2010
    • 7
    #46
    Cheers CK
    I've had a look around for a answer to this but i'm sure you can give a clearer answer. Should I manage to successfully carry out this 4.3E mod, would it be then possible to put a game on the SD card I mentioned above and play it on the modded Wii??
    Also. Will the original games on disc we already have load as normal??
    • ck-ok
      • 2592
      #47
      Originally posted by Bones77
      Cheers CK
      is there ever a easy answer .
      try formatting a sd card to wbfs putting your backup on it and run through neogamma,you might get it running through a usb loader by putting the card into a card reader and plugging that into one of the usb ports.
      but to be honest you will be better off with a usb pen or a hdd
      • Bones77
        • Nov 2010
        • 7
        #48
        Bloomin eck. Here's me thinking plug and play
        Will mostly be doing dvd-r backups, but seeing as some backups are under 1.0gb I though about the sd card method.
        Got WBFS Manager 3.0. Had a google around for neogamma and there seems to be a quite a few versions of it. Any particular one we would require for 4.3e, or do all the neos work on 4.3e ??
        Will neogamma affect anything in the 4.3e mod I will be doing?
        • ck-ok
          • 2592
          #49
          neogamma is included in the download and tut.
          is your wii new or has it been updated to 4.3?
          • Bones77
            • Nov 2010
            • 7
            #50
            Thanks for the reply CK OK
            The Wii is 2 years old and i'm assuming it will have updated to 4.3e in the summer when i'm sure I clicked on update on the console.
            I've just ran and formatted a 1gb sd using WBFS Manager, so now it's onto sorting out the 4.3e mod.
            We have a card reader so once the mod is sorted out will it be a case of trying a backup on the sd card and plugging into one of the usb ports and running through neogamma?
            Like I say my main priority is back ups on discs but for smaller files i'd like to try the SD card.
            Thanks again
            • dynomikered
              • Jul 2010
              • 78
              #51
              hi first post so go easy, i have followed the tut to the letter. Every thing worked untill i get to the priiloder install, it says installed wait 5 seconds but then i just get a black screen with white lines on it, i have tried reset and power turning on and off but it just loads the main menue of multi mod ! please help as wife and kids will kill me if i can not get this to work
              cheers
              mike
              • ck-ok
                • 2592
                #52
                cheers
                mike
                hold in reset button while powering up should get you into priiloader,if it does set it to boot to system menu and save.
                then reboot.
                • dynomikered
                  • Jul 2010
                  • 78
                  #53
                  Thanks for the reply, i have done the hold reset thing but when it comes on it boots to main menu multi mod.
                  I am howerver able edit priiloder hacks and save prefrences, if this is what i am looking for i apologise. i will see if i can set it to boot to system. sorry for all the nood questions but do i leave the sd card in after the install and can u recomend a program to get the dvd(movies )to play
                  thanks in advance
                  mike
                  • ck-ok
                    • 2592
                    #54
                    thanks in advance
                    mike
                    for movies try this post http://www.digital-kaos.co.uk/forums...ies-wii-96949/
                    • dynomikered
                      • Jul 2010
                      • 78
                      #55
                      Thanks for the movie post. As for the SD card do i leave it in after the install, when i take it out i have nothing in HBC. Once again sorry about the noob questions but im pretty new to all this and made the plunge affter reading lots on this great forum!(but not enough by the looks of it :-)
                      • ck-ok
                        • 2592
                        #56
                        sorry forgot that one,yes best to leave it in.
                        • dynomikered
                          • Jul 2010
                          • 78
                          #57
                          ck-ok, as before i dont get the priiloader screen(do u have a screen shot) when i reset boot , i just get the mmmm but there is an option for priiloader edit in this menu. is this what i am looking for? i can disable updates and game updates as well as other hacks
                          many thanks
                          mike
                          • ck-ok
                            • 2592
                            #58
                            many thanks
                            mike
                            If MMM loads at boot, select Manage Priiloader, Edit Priiloader Hacks, enable needed hacks.
                            there should be a hack that says boot too system menu
                            • Bones77
                              • Nov 2010
                              • 7
                              #59
                              Next question
                              Whats all this NTFS FATS32 all about???????
                              Just tried to winrar a file but eventually it popped up something about being over 4GB not happening because I am not on NTFS. This obviously means i'm on fats32 (I checked)
                              What next?? Apart from investing in a HDD
                              But in the meantime does this mean I nead to convert C: Drive to NTFS?? or can I leave it at FATS32, or is there something simple i'm not doing so the files above 4gb open.
                              Don't want to wipe my PC out
                              Cheers
                              • ck-ok
                                • 2592
                                #60
                                Next question
                                Cheers
                                my pc is ntfs and no probs here
