Black Ops for Wii
  • a12arm
    • 210
    #31
    Originally posted by barrowmanandrew
    i have wii softmodded 4.3.
    i load game games via h/d using configirable usb loader.
    i see posts saying to change ios loader from 222 to 224.
    i only have options for 222 and 223???
    can someone explain in " idiot language", what i am doing wrong and how to fix it please...
    i am a total noob with wii stuff, any help appreciated...
    You need to install ios 224 (57) v5.1 from here: using wad manager
    then set config usb
    • Configurable USB Loader -> Select The Game-> Press 1 to go into Options-> IOS = 224 you want to use for the game -- Press 2 to save
    • reddevil157
      • 1427
      #32
      Tried 224 [57] v5.1.wad on CFG rev 60 with no luck, tried 249 [57] rev20.wad and it worked on CFG rev 60.
      Tried disc load { back up} 249 [57] rev 20 on Neogamm r8 and worked, but the wii was grunting and groaning at me, any idea's anyone ? on the noise that is?
      Red.
      • billy2
        • 1381
        #33
        also working for me on 249 [57] rev20.wad with loader gx
        • a12arm
          • 210
          #34
          Still can't get usb loadergx to work tried both 249 v19 & V20
          and 250 V20 wondering if it's the game!!!!!
          the only reason I have not tried another loader is because all my other games work fine
          What version of the COD game are peeps using?
          mine was (imars-codbo PAL)
          • reddevil157
            • 1427
            #35
            What rev GX are you on ?.
            You do know you can have more than one usb loader.
            I d/l and burned a pal iso.
            • Timmaa
              • 88
              #36
              Originally posted by ck-ok
              you can use the 5.1 installer from here to get 224 up todate http://www.digital-kaos.co.uk/forums...taller-143444/
              I put the game on my HDD, selected IOS224 under uLoader 4.9 but it hung whilst loading the game. So I assume I need to upgrade my cIOS224.
              I've downloaded those 5.1 packs but TBH I'm not sure what to do with them. Should I put the boot.dol from the cios_installer folder of the uloader archive into the root of my SD card and boot from SD just to upgrade the cIOS or should I do the whole lot?
              Would it be easier to use the internet updater? Will that do uLoader and the cIOS and still retain my forwarder channel or should I remove that first?
              That's the trouble with these kits that do everything for you; when something goes wrong you don't know bits to replace!
              • ck-ok
                • 2592
                #37
                put cios installer in apps folder start homebrew start cios5.1 installer,select 224 install with base of 57 that should be it no need to change anything else then boot game using 224
                • happy_highlander
                  • 3535
                  #38
                  I am running the same version of the game and have it running perfectly on the usbloader gx 938 and cIOS 249[57]v20. I have uploaded both files into the downloads section.
                  • Evilbert
                    • 114
                    #39
                    Please forgive me i usually only hang out on the satellite boards but was wondering if any experts can help with this. I'm trying to load an ntsc version on a softmodded wii from disk, running neogamma r9 b47 cios57rev 20 and i keep getting a black scree. The same happens when using uloader. Any ideas where i'm going wrong, its starting to drive me a little nuts now. Cheers Bert
                    • a12arm
                      • 210
                      #40
                      Tried loader gx 937 & 938 but found it not working as smooth as older version installed as a channel
                      will give this another go I'll check game with another usb loader Maybe config usb loader and reinstall iso249 & 250
                      can't believe i'm having this much trouble
                      thanks for the help
                      • happy_highlander
                        • 3535
                        #41
                        thanks for the help
                        The version of gx shouldn't matter just put Digital Kaos - Downloads - cIOS240[57]-v20 for COD black ops in wads and install. I know this is working. If you still have problems try another iso. I have just noticed the link says cIOS 240 it is 249 I have just edited in downloads, sorry if it's confusing peeps.
                        Last edited by happy_highlander; 12 November, 2010, 21:17. Reason: I'm an idiot and don't look ot titles when uploading.
                        • Timmaa
                          • 88
                          #42
                          See that's the thing about you ck-ok. You're the f?cking man. I've just tested zombie mode and online with no issues whatsoever.
                          Running uLoader 4.9 with an upgraded version of cIOS224.
                          Rep added. Love you man.
                          edit: but out of interest, how did you know about the base 57 bit?
                          • ck-ok
                            • 2592
                            #43
                            thank you for the comment, hope you enjoy the game.
                            as for 57 as a base,all the solutions in this thread are based on a base of 57 but because you are using uloader by hermes it stood to reason that hermes 5.1 installer would be the most compatable for you.
                            • Evilbert
                              • 114
                              #44
                              Has anybody got it to work from backup disc yet?
                              • ck-ok
                                • 2592
                                #45
                                if your using uloader try reading from post 36
