Can anyone re-up .pdf?
PS3 LIGHT OF DEATH FIX
I think the XBOX 360 has suffered from the same problem for ages as well.
However it all depends on how the repair was done. If they just replace the heat paste it won't last long.
A lot of the problem is the way the parts are put on the circuit board. If more care was taken there woundn't be a problem with corrosion/ solder oxidising.Comment
Mine is still going strong after a couple of months after "fix"....should i look for a new one just in case?....what lifespan are folk experiencing after fixing a few times?Comment
I got the dreaded YLOD yesterday so hopefully this will fix it, As long as the PS3 lasts long enough to backup everything I'll be happy, Thanks.Comment
FYI, If you want to read the pdf file for this fix, you have to;
1. Register
2. Click on the link in your valid e-mail that you used to register
3. Post on the Forum
4. Wait about 15 minutes, and then you're supposed to be able to download pdf files.
... yeah... 'cause I'm not already super frustrated the my PS3 won't start....Comment
Result! It worked, Well its booted up fine, I still have to try a game to see if anything happens. I wish I'd have kept the VOID sticker intact and I would've traded it in. Oh and ?40 on a heat gun because no shops had any cheap ones in
