Dell Mini Inspiron 1012 - Please help recover Bios and Hdd Pass
  • smoggy
    • Apr 2009
    • 12772
    #61
    Originally posted by hsdavisjr
    I tryed in that order....
    xmb
    sqqbw
    687989
    The xmb got me thru the bios i guess,
    now its asking for a Hdd Password
    gives me error code [14876]
    syst serv tag [9hk7mk1]
    Again thanks for all the help, i done took out the cmos battery over night,
    put it back together this am.. BUT... it showed me other stuff like the bios AO6, the prcessor speed ect,
    said 0271 check date and time AND 0251 system cmos checksum bad? default settings set?
    then it gave me choice to enter set up? or proceed, I entered the setup to adjust clock and remove old password,
    But it went to the password thing again so i entered in the XMB it passed thru but then came up with the Hdd password?
    Also I downloaded the Dell_Boot_ISO.rar file and was going to try that, but there is no cdrom just a card reader slot...
    It wont boot to the card, so i think it is set to boot to hard drive and skip card..
    Again i would like to say thanks ahead of time and for taking your time to help me....
    I have never seen a successful code given for HDD error code
    the error code produces these codes but if they don't work you need to find other means
    amah
    davskvd
    5649212
    • hsdavisjr
      • Mar 2013
      • 7
      #62
      yeah I tryed them too Nope They didnt work....
      When You say "if they don't work you need to find other means"
      Does that mean new hhd or motherboard? "im thinking it's a wash out"
      and dont wanna give up... stuborn like that, I personally dont
      know any other means.. but will keep searching n trying,
      if it wont boot to the card reader and goes str8 to the password
      first it wants the admin password, i put in the one you gave me that worked....
      XMB
      it then asks for hdd password.... i then entered each one of theses
      amah
      davskvd
      5649212
      then gives me
      error code [14876]
      sys serv tag [9hk7mk1]
      IN order...
      but nope
      ANY thoughts or idea's?
      I would be good if i could get it to boot from card reader im thnking
      i could just do a restore on it but?
      • smoggy
        • Apr 2009
        • 12772
        #63
        XMB
        amah
        davskvd
        5649212
        then gives me
        error code [14876]
        IN order...
        but nope
        I'm quoting what worked for someone else, it may not work for you
        remove HDD and boot into BIOS
        set an admin password
        shut down and re-inseret HDD
        boot back into BIOS and select option to remove HDD password
        • hsdavisjr
          • Mar 2013
          • 7
          #64
          thought i had it
          i hit the f2 key on boot.. ask for pw. i entered the one you sent xmb
          took me right into phoenix bios setup utility... I was happy for a sec LOL
          i went to security Reset supervisor password When asked for old one i used XMB again
          I then could change the PW. went to USER pw and repeated above steps WORKED
          Then came the hhd pw :/ not able to change, Says SET... Below that it says set HHD PW
          TRYED.... again entered the ones you gave me... Gave me new error code
          [23130] and systm same number... hmmmm so i restarted the mini, came up passing everything but the hhd pw
          I again restarted it hit f2 for bios setup, it ask for pw, I put in the one I reset it to... right in, so HALF WAY HOME....
          I then looked to see if i could set it to boot from card reader.... didnt see option...
          any ideas?
          Thanks again for all your info and input
          • hsdavisjr
            • Mar 2013
            • 7
            #65
            nope no work did that I also figured how to make card reader boot first but still ask for hhd pw
            • BISCOCHITO
              • Apr 2013
              System Disable [23130]
              Hdd password error code [07343]
              System Service Tag Code [4LBK2M1]
              Please Help... My Mini has a HDD Password!
              • smoggy
                • Apr 2009
                • 12772
                #67
                you cannot calculate Mini HDD passwords only BIOS password
