Epson P50 waste ink pad counter
  • Canker_Canison
    • 3904
    #46
    Originally posted by asimh
    after resetting p50, should i clean waste ink tank. thank your prompt reply
    That is up to you. If you don't do anything, the printer will eventually start to leak over your desk.
    Changing the pads isn't the easiest job. But connecting a longer pipe is very easy.
    How's your Russian?
    Срок регистрации домена истек. Требуется продление, чтобы возобновить работу домена и его сервисов
    Canker
    [COLOR=Green]
    • efpe
      • Jan 2013
      p50 pain
      Hi, I'm new here. Been jumping through hoops like a circus poodle trying to get a reset utility for my printers. I have 4 p50's printing cd's meant for distribution for a corporate client. 2 of these printers are now inisting on getting serviced. The ssc thing i used for my older printers is obsolete, can you please help out?
      Efpe
      • ttt123
        • 22
        #48
        Thanx for this Canker.I`ve used the WIC utility before but it does not cater for the P50. i just stumbled across your programme while having a general browse on here.It works perfectly.
        Thankyou.
        ttt.
        • nidzaking
          • Feb 2013
          do you have to buy a key to reset?
          • qwequ
            • Feb 2013
            how is the reset done?
            • kampuni kubwa
              • Feb 2013
              p50 t50
              do p50 and t50 use the same reset
              • ramafoto
                • Feb 2013
                is this still working?
                • madaoaie
                  • Feb 2013
                  Hi!
                  How many time I can use this, before I actualy have to replace the Ink pad.
                  Thanks!
                  • andy91
                    • 3583
                    #54
                    Originally posted by madaoaie
                    Hi!
                    Thanks!
                    Its there for a reason as in time the waste ink will overflow.
                    Best thing to do is check your printer and try and mop up the excess ink with some tissues.
                    Waste ink collects in an area with a sponge on most printers.
                    That way you wont have an inky carpet.
                    Andy.
                    • bonehead1
                      • Mar 2013
                      Can this be used for a artisan 50 ?
                      • Canker_Canison
                        • 3904
                        #56
                        Yes
                        Yes
                        Hi!
                        Thanks!
                        Once. I would advise bypassing the waste pipe.
                        Small square cover on the back of the printer. Think it's held in place by a single screw. Clear pipe inside can be pulled away from a connector & extended to a collection tank of your choosing.
                        Try googling 'epson P50 waste ink mod'
                        Canker
                        [COLOR=Green]
                        • viokara
                          • Mar 2013
                          Epson P50
                          If i don't charnge that waste pad, could be a problem on long run?
                          • ciupercutz
                            • Mar 2013
                            Depends on how much you have invested in you're printer. I paid 200$ for P50 with CISS, and printed more than 5 liters of ink, so, it already paid off, i just need to use is until it snaps definetively.
                            Sorry for the crapy english.
                            • ventaak
                              • Mar 2013
                              #59
                              I'm going to download this and try it for the Epson Artisan 800. If this is the wrong program for the 800, anyone know where I can find the right one?
                              • Canker_Canison
                                • 3904
                                #60
                                I left this link to Epson on another post.
                                Canker
                                [COLOR=Green]
