Hey guys,
It took me ages to source a SX125 waste counter reset program that works, so I thought I would pop it on here.
I've uploaded it into the download section, but thought I may as well pop it on here with a bit of guide too.
I've only tested it on XP 32bit, with a UK SX125 printer, so that's what the instructions will be tailored for. By all means try it on other OS's and feel free to post results.
Reset instructions for SX125:
Job done, carry on printing!
I recommend getting a waste ink tank for your printer, have a Google for one, the waste ink pipe is easily accessible from a clip in hatch on the back of the printer.
Hope that helps, if it's useful, don't forget to thank
J.
right, rubbish is still being posted to gain access to this file even after a warning, i will say this one more time, DONT KEEP POSTING RUBBISH TO GAIN ACCESS TO THIS FILE, keep your posts to questions or an answer to another post, THE NEXT PERSON WHO POSTS.....THANKS OR GOOD POST OR JUST WHAT I NEEDED OR ANY OTHER RUBBISH TO GAIN ACCESS TO THIS FILE WILL BE BANNED, YOU HAVE BEEN WARNED !!! DK STAFF
YOUR FIRST POST GOES HERE-----> http://www.digital-kaos.co.uk/forums/f2/
- Install printer if not already installed.
- Download and extract attached file into a folder on your hard drive.
- Run 'AdjProg.exe' and click 'Accept' on the splash screen then click on 'Select' at the top.
- From the pull down boxes, select 'Epson Stylus TX121' for 'Model Name' and 'ESP' for 'Destination', click 'OK'.
- Click 'Particular adjustment mode' then from the '---- Maintenance ----' section, select 'Waste ink pad counter' then click 'OK'.
- Click 'Check' on the bottom right, this will query the printer and give information of ink shots and so on.
- Tick the two boxes on the left, 'Main Pad Counter' and 'FL Box Counter', then click 'Initialize'.
- It should come up with a message abut restarting your printer, do it!
J.
black cartridge not recognized, but till yesterday it worked and the cartridge had some ink remaining...
) for more talks. Thanks once again.
