Epson SX125 waste ink counter reset
  • akramjef
    • Apr 2012
    • 15
    #16
    waste ink overflow
    dear andy91
    there is small door on the back of the printer , if you open it you will find a tube which carry the waste ink to the waste pad, disconnect it from the pad and connect it to out side waste ink container ( do-it-yourself). this is what i did to my printer and till now there is no single drop of ink on the pad.
    • thadeus
      • May 2012
      thank you
      it is working
      model sx125
      a little pdf guide with images...
      download here
      • jacklee
        • May 2012
        sx125
        dose the resetter work
        i have alot of epson resetters so if you need any inbox me with email
        • gspeedy
          • Apr 2009
          • 190
          #19
          Will this work on SX110 or SX115 ?
          HAPPY NEW YEAR, DK MEMBERS!
            nearly 50 thanks posts have been deleted from here, please use the thanks button located bottom right of each post, thanks posts just clog up the threads and make them harder to navigate.and please dont post any crap they will also be deleted.it is also customary and polite on any forums to make your first post here---> http://www.digital-kaos.co.uk/forums/f2/
            • renooshka
              • May 2012
              Originally posted by akramjef
              dear andy91
              "connect it to out side waste ink container" where I dont understand?
              • Canker_Canison
                • 3904
                #22
                On the back of the printer is a small door.
                Behind that door is a clear pipe that takes the waste ink to an absorbant pad.
                Disconnect the clear pipe from the bottom connector
                Gently pull the pipe outside of the printer
                Either extend the pipe, or find a container that can reach the pipe, so waste ink will be collected outside the printer.
                Canker
                [COLOR=Green]
                • wahrani31jackson
                  • May 2012
                  #23
                  dear johnnybeast
                  i'm trynig hard to download the file you 've posted but i can't do because it showing me a message that i have to wait ...or something i don't anderstand ...can you help me to download it ?? thank you much !
                  • wahrani31jackson
                    • May 2012
                    #24
                    i tried to download it ...but it doesn't want to get me the file ...could you help me to download it ?? thank you !
                    • smirnoff_rules
                      • 8603
                      #25
                      Originally posted by wahrani31jackson
                      dear johnnybeast
                      wot part of ( i have to wait ) is the problem .. give the server time to update u as a new member, and stick around m8 . theres thousands of things on here to learn
                      • mayhem2008
                        • May 2012
                        Waste Ink
                        Looking for a way to reset my SX125 Printer. Tried a few programs but no luck yet ;-(
                        • feyizu
                          • May 2012
                          Hii, dear;
                          I have an Epson SX425W printer and looking for waste ink tank resetter..If you have this can you send me.
                          Great thanks for your effort in advance.
                          Please send it to:
                          ( no addys )
                          • ivanvk
                            • May 2012
                            sx 125
                            hi i have a problem with epson sx 125. after changing cartridge there is still a notice that the ink is empty. can you please tell me which program i need to use to reset my epson. sorry for bad english... thanks!
                            • Canker_Canison
                              • 3904
                              #29
                              You don't need to reset the printer, you need to remove the cartridges & wipe the chips before putting them back in.
                              If that don't work, take them back to the shop.
                              Compatable cartridges don't always work.
                              Canker
                              [COLOR=Green]
                              • epsonsx230
                                • Jun 2012
                                Hi !
                                I saw that already works on SX125 and SX130.
                                Does this software work on Epson Stylus SX230 ?
                                Thanks in advanced.
