Epson SX125 waste ink counter reset
  • AxisStarstreamer
    • Jun 2013
    #241
    it didn't work for me (win8 64bit), but maybe this wasn't the problem
    • wush3
      • Aug 2013
      MY sx125 suddenly stopped recognizing its cartridges ( they were about half full before this started) I hope the reset tool can help me.., These chip restriction suck! My next printer will be something else... What would you recommend? canon, hp or something else ?
      • Canker_Canison
        • 3904
        #243
        This program will not solve your problem. You need to buy new inks.
        THE WASTE INK COUNTER RESET SOFTWARE ONLY RESETS THE WASTE INK COUNTER. NOTHING ELSE.
        I really thought the name would of explained what it does.
        Canker
        [COLOR=Green]
        • Hollie92
          • Nov 2013
          I was just wondering if this would work for resetting the chip when manually re-filling ink cartridges?
          • Jokan
            • Dec 2013
            #245
            Man Johny! Your program is wonderful, its working and now my printer is back to life.
            Live long man Johny.
            in addition to that there is this pipe i found on the printer from the back which seems to be inserted on a hole attached to the carpet, and i decide to take it out directed it to an outside bottle so that the ink goes into the bottle. is it wise to do this?
            Thanks a lot.
            • behocines
              • Jan 2014
              Hi
              I'm looking for a resetter for my XP205.
              All my searches on the net gave the same answer: just pay for a key.
              There is no other way?
              • monyli
                • Sep 2013
                Holla HELP!!!!!!
                i have a big problem with my sx125 i change eeprom data with epson adjustment prog the printer Has become tx 121
                and i need help and solution to fix this problem
                with flash or reset the printer
                • Canker_Canison
                  • 3904
                  #248
                  Originally posted by monyli
                  Holla HELP!!!!!!
                  You will need to find a source for the correct firmware. As far as I'm aware nobody here has printer firmware.
                  Canker
                  [COLOR=Green]
                  • dinoon
                    • Feb 2014
                    Please, i have epson sx105, i tried many resetters but nothing work
                    • werranntezone
                      • Feb 2014
                      #250
                      I didn't work for me (SX125). I'll try to buy new inks.
                      • werranntezone
                        • Feb 2014
                        #251
                        SX125_TX121_Engineers_Software.zip | xup.in
                        SX125_TX121_Engineers_Software.7z | xup.in
                        • icemantaz
                          • Apr 2010
                          #252
                          Originally posted by behocines
                          Hi
                          Im having the same problem with an xp-205. Did you find a solution?
                          • essahco
                            • Oct 2013
                            #253
                            epson sx 125 has turned epson tx 121 through this programme.what should i do,
                            epson sx 125 has turned epson tx 121 through this programme.what should i do, it had errorles set to intial settings
                            • lakis20vt
                              • Apr 2014
                              ty very much its work at sx130 !!!!!! thank youuu
                              • lilibularca
                                • Apr 2014
                                #255
                                It worked! Epson SX125 waste ink counter was reset
                                THANK YOU VERY MUCH!SX125 TX121 Engineers Software.rarSX125 TX121 Engineers Software.rar
