pc wont boot
  • spondulick
    • 677
    #31
    nothing on motherboard disk ,what do you mean swapping stuff.
    • spondulick
      • 677
      #32
      cant get anything on monitor mcgeoff.
      • mcgeoff
        • 63
        #33
        Have you tried another graphics card
        • cunny
          • 4915
          #34
          unplug all drives from motherboard an try another graphics card.
          • davemac82
            • 279
            #35
            Sounds to me like you have pushed something either ram or cpu from its seating. I would......
            1. Remove board from case.
            2. remove cpu fan and cpu. and any other hardware ie ram
            3. replace board into case.
            4. re seat cpu and fan
            5. fit original ram to slot 0
            6. connect power supply
            7. try and boot computer with only vga cable and power cable plugged in.
            • sattboy
              • Mar 2009
              • 84
              #36
              Originally posted by spondulick
              sorry to mess u about but sound is beep pause beep pause and so on
              hi m8 re-install the original mem stick boot it up,while booting hit F2 or DEL and enter bios and see if bios is registering any mem at all you may have to set bios to defualt settings this should work.always keep mem to same type and value ie you should always have matched pairs.cheers m8
              • davemac82
                • 279
                #37
                He cant get the board to post so how could he possibly access a bios!!
                • cunny
                  • 4915
                  #38
                  Keep it to the basics hey guys, try another gfx card with orig dimm of memory in, unlug everything else, if that fails, try newer memory, if that also fails given everything thats been tried then it sounds like the board as died.
