dell latitude d630 admin password ??
  • mystik205
    • Dec 2011
    #1276
    I am a Technician for EZ pawn here in Birmingham, Alabama. A customer brought in their Dell Laptop to pawn. They did not return to get it so it dropped out. It hass a Admin password on it and we can't get into it to clean out the old programs and files the Serv. Tag is: 846FRG1.......HELP!
    • smoggy
      • Apr 2009
      • 12772
      #1277
      calculated with a suffix of -595B (if you can see any different then post it)
      password d7ajdnw5
      • smoggy
        • Apr 2009
        • 12772
        #1278
        Originally posted by dablues17
        Hey I have a Dell Latitude E5400...
        I really need to get pass the administrator password. #5R6ZYJ1-2A7B
        Thanks soo much in advance
        password poUx07ZU0Hp4KOOV 5th and 9th are zero's - 2nd lower case and 14th-15th uper case O for orange
        note changes from upper to lower case as tags and passwords are case sensitive
        • marijn-onlijn
          • Feb 2010
          #1279
          hello there,
          i have a dell inspirion 9400
          i have the code #85WD32J-595B
          i did run a little program wich gave me the password : nnqo14hv
          but i isn't the right password.
          any help would be nice,
          regards
          Marijn
          • smoggy
            • Apr 2009
            • 12772
            #1280
            regards
            Marijn
            that password is correct for a QWERTY type keyboard
            are you entering it in lower case also 4th is o for orange
            have you tried holding down CTRL key when pressing enter
            • linglang
              • 18
              #1281
              Request for unlockcode for E6420 #FKZK4R1-1D3B asks for it.
              I want to install my o.s. fresh , but can not change boot order.
              • smoggy
                • Apr 2009
                • 12772
                #1282
                laptop is too new, not possible with our calculator
                at present only done by websites that charge for service
                • Unique12345
                  • Dec 2011
                  Bios bypass
                  Originally posted by egyclick
                  I can help you guys for removing Dell Bios Password, just reply with your service tag here
                  cheers
                  Thanks a heap for helping everyone out here. Im not entirely sure if its the bios or hd password but it says password authentication system. Here are the details if you could be so kind.. its been a nightmare!!
                  #GRP54R1-1D3B
                  Its a toshiba latitude e6320
                  Thanks again
                  • smoggy
                    • Apr 2009
                    • 12772
                    #1284
                    #GRP54R1-1D3B
                    Thanks again
                    suffix -1D3B
                    • brownylee
                      • Dec 2011
                      #1285
                      Hi. I have bought a 2nd hand Latitude D630 and need the administrator password. The computer system reference is DHCR24J-595B
                      • smoggy
                        • Apr 2009
                        • 12772
                        #1286
                        first post should be here Introduce Yourself
                        say hello and join the community
                        in the meantime password 66tob502 4th is o for orange and 7th is a zero
                        • sul3sul
                          • Dec 2011
                          I Have A Dell Latitude E6220 Laptop I Need A Bios Password
                          The Number That Comes Up When Booted Is 3Z8PYQ1-1D3B
                          SERVICE TAG : 3Z8PYQ1
                          EXPRESS SERVICE CODE : 8661311497
                          I Hope This Is What You Need,
                          • brownylee
                            • Dec 2011
                            #1288
                            Thank you for your reply, however it says I need a different password now, a HD password, can you help with this please?
                            • brownylee
                              • Dec 2011
                              #1289
                              It also has a different reference now. It says #***5TF04AA3-595B
                              • smoggy
                                • Apr 2009
                                • 12772
                                #1290
                                I calculated with the 7th as a zero
                                pssword y73k0d33 5th is a zero
                                but this will only work if it is the original HDD
