dell latitude d630 admin password ??
  • smoggy
    • Apr 2009
    • 12772
    #1351
    Originally posted by johndoe1
    Thanks smoggy, however that password didn't seem to work. Is there anything else i could try?
    I calculated with a -595B suffix if you can see anything different post it
    the trouble with service tags that dont have a -xxxx suffix is they can be the new type that cannot be calculated with this calc.
    you could try inputting wrong password 3 times and see if it gives you a code
    also password needs to inputted in lower case and 3rd is a l for leg not a 0ne
    • johndoe1
      • Dec 2011
      #1352
      i believe it may be 9BGF5QI - 1D3B?
      • smoggy
        • Apr 2009
        • 12772
        #1353
        sorry but suffix 1D3B is too new, only by Dell or websites that charge big bucks
        • remii
          • Dec 2011
          #1354
          Originally posted by smoggy
          first post should be here Introduce Yourself
          say hello and join the community
          your tag has 1 too many characters
          Hello Smoggy,
          You're right, my bad. Code is #7CBQP3J-595B
          I've posted a presentation here
          • djc1977
            • Dec 2011
            #1355
            service tag is JSV0QH1
            Thanks!
            • smoggy
              • Apr 2009
              • 12772
              #1356
              Originally posted by remii
              Hello Smoggy,
              password j5nz81h0 last is a zero
              • djc1977
                • Dec 2011
                #1357
                Hello I came across this website in my search for help. PRetty neat forum i might add. I purchased this Dell Latitude D630 on ebay for my mom for christmas and it has a bios/administrative password on it, so i can't do anything with it. Christmas is a week away...someone please help....my service tag is JSV0QH1-525B
                THANKS IN ADVANCE!
                • smoggy
                  • Apr 2009
                  • 12772
                  #1358
                  THANKS IN ADVANCE!
                  I've assumed 4th in tag is a zero and it ends 595B
                  try vnveuwv7
                  • djc1977
                    • Dec 2011
                    #1359
                    it worked! Thanks and God bless!! Have a happy holidays!
                    • remii
                      • Dec 2011
                      #1360
                      Thank you so much smoggy !!!!!
                      • razz40
                        • Dec 2011
                        #1361
                        thanks for any help you give
                        I have an refurbished dell d630 that is bios protected and i cant install new OS. My Service Tag is : 2FP44F1-595B
                        • lmsvvavr
                          • Jul 2010
                          • 569
                          #1362
                          Your password should be: d3c3ao67
                          "o" from "old"
                          Hit Thanks if helped you!
                          Thank You for the help!
                          "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
                          http://www.youtube.com/c/LMAutoRepairs
                          • Partyloewe
                            • Dec 2011
                            • 7
                            #1363
                            these are the only other passwords that it can be
                            if they don't work try inputting wrong password 3 times and see if it gives you a 5 number code
                            3o82cngw 2nd is o for orange
                            ij1TM4a1Jr05bZ8k 11th is a zero and note changes from upper to lower case
                            passwords must be inputted in the case given and they are for a QWERTY type keyboard
                            There is no 5 diggit code and
                            the two passwords don't work either!
                            • smoggy
                              • Apr 2009
                              • 12772
                              #1364
                              in that case your model cannot be calculated with the dell calculator
                              • razz40
                                • Dec 2011
                                #1365
                                Thank You Imsvvavr
                                Your password worked like a charm ,I just joined and I have found so many great tips on this forum..
