dell latitude d630 admin password ??
  • smoggy
    • Apr 2009
    • 12773
    #1816
    Originally posted by CorePax
    If I start the laptop. I see the bios loading screen, there I'm presented with 2 options
    -F2 to enter Bios (If I press this the screen will finish loading and lead to the white screen)
    -F12 to select boot device (This also leads to the white screen)
    Not pressing anything also leads to the white screen. I've tried both F2/F12 and no key at all while having a bootable disk in the laptop.
    Still nothing seems to be working
    have you tried F2 to BIOS and then try password
    • CorePax
      • May 2012
      • 7
      #1817
      Yes I did, But it still said the password was wrong.
      • smoggy
        • Apr 2009
        • 12773
        #1818
        only other thing I can suggest is to try a usb keyboard just in case one of the keys on the laptop is malfunctioning.
        or if its a newish laptop it might be 2nd generation of suffix -595B which cannot be calculated with our calcs
        • CorePax
          • May 2012
          • 7
          #1819
          I've tried to use another keyboard but it gave me the same result. And I don't think it's a very recent model since there's a sticker on the bottom saying that the warranty expires in 13/10/2010.
          Once again thanks for helping me
          • Disillusionist
            • May 2012
            #1820
            Please help me with the pass for the following:
            Service tag: D6SS63J
            Express service code: 287-093-109-43
            Thanks in advance.
            • smoggy
              • Apr 2009
              • 12773
              #1821
              Thanks in advance.
              for qwerty type keyboard try 596vmqcl 8th is l for leg
              • Disillusionist
                • May 2012
                #1822
                Many thanks Smoggy!
                Worked like a charm.
                • kinget
                  • 16
                  #1823
                  Hi! I need help with the pass for a Latitude E6500.
                  Servicetag: BMN784J
                  HDD no: #XM209SN2470-2A7B
                  Express service code: 253-138-298-59
                  • smoggy
                    • Apr 2009
                    • 12773
                    #1824
                    Servicetag: BMN784J
                    try Yxdvxdp9Pb3p6bsr note changes from upper to lower case
                    • kinget
                      • 16
                      #1825
                      Sorry, didn't work...
                      any more ideas?
                      • smoggy
                        • Apr 2009
                        • 12773
                        #1826
                        any more ideas?
                        the password is to get into BIOS only
                        as your HDD had suffix 2A7B I calculated your service tag as being the same
                        try this calculated with suffix -595B mwle5g4p 3rd is l for leg
                        also on first password did you try pressing Ctrl + Enter
                        • kinget
                          • 16
                          #1827
                          Ctrl + Enter didn't work.
                          not the calculated suffix you gave me either...
                          do you need more information about the machine?
                          • smoggy
                            • Apr 2009
                            • 12773
                            #1828
                            are you trying to get into the BIOS settings or are you wanting Admin password.
                            the passwords I gave are only for BIOS.
                            the service tag is normally followed with a suffix like -595B the suffix is needed to calculate password
                            I have to go now so will get back to you later
                            • kinget
                              • 16
                              #1829
                              sorry for not being clear! it's the hdd-password im after!
                              • smoggy
                                • Apr 2009
                                • 12773
                                #1830
                                HDD password should be LnZH51B6Z3sx2Lo0 15th is o for orange and last is a zero
