dell latitude d630 admin password ??
Hit Thanks if helped you!
Thank You for the help!
"A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
http://www.youtube.com/c/LMAutoRepairs -
REMOVE DELL BIOS HDD PASSWORD
If you're getting an HDD password request during the initialization, you can remove it by entering a new admin password (an HDD password can't be made unless an admin pass was created first)...after failing the 3rd attempt in entering the HDD pass, do not push enter the 2nd time (causes shut down and you'll have to start the process all over again)...hold F2, while holding F2, push ENTER, your shut down process should be bypassed allowing you to enter the BIOS utility page (if you didn't enter the utility page, you didn't follow the steps carefully...start over!) This is where it gets a little annoying, tricky, and sometimes frustrating...and sometimes it'll work so smoothly that you'll forget you had an HDD pass...
While in the utility page, go to the tab/page that allows you to enter an admin pass, if you can set one, choose an easy password, this password will override the HDD pass (the password you didn't know)...go to "Set HDD password" enter the newly created Admin password, it'll give you an option for a new password LEAVE IT BLANK (just push enter twice), you should see the status of the passwords as you change these settings...now go back to the "Set Admin password", enter the easy password you chose, leave the new password blank...all your password status's should be "Not Set"... now go to your utility exit option and SAVE Changes and Exit (or reset, whatever option they give you)...you should have no passwords that are required when your system boots!Comment
Hello, i found this website via a google search and came across this post. I am attempting to reset a Dell Latitude D630 Bios (Setup) Password, i have the dell.exe file and it is giving me a password that will not work
Service tag is: 6c4m2f1-595bComment
first post should be here Introduce Yourself
say hello and join the community
in the meantime try xe7lcdve 4th is l for legComment
You sir, are a lifesaver, thank you for helping so fast.Hi
Point Breakdown:
Points for style 10
Points for grace 100
Points for quick reply 9,001 (It's Over 9000!)
Thank you.
If there is anything i can do in the future to assist you, just drop me a PMComment
Try this A46N7yYKlKEM28C7 ninth is l for limaOriginally posted by suny777dell latitude e6410 admin r sistom password #7JTG62S-2A7BComment
in the meantime try z9plfv38 4th is l for legComment
BIOS Password help please
Having battled for the last week to get a Dell D630 I was given actually working ive now reached the next hurdle - the BIOS is passworded. I would be very grateful for your help please. The service tag in question is :- 8Y3MQ3J-595B
THANKS IN ADVANCE!Comment
in the meantime try 80q7sl99 2nd is a zero and 6th l for legComment
Try this 80q7sl99 second is zero and sixth is l for limaComment
