Bossa's Guide to Activate windows 7 with not genuine software message in corner.
First of all open Command Prompt which is in Start Menu , All Programs , Accessories ... but you must run as administrator.
Then simply type in this command:
slmgr -rearm
Within a few seconds you?ll normally see this dialog show up, saying that the command has completed successfully, at which point you?ll want to reboot.
Now don't panic you will still get the not genuine message at start up but it shouldn't be in the corner
of your desktop anymore.
So Checking the system properties again shows that you now have so many days left to activate.
Now run the Windows 7 Loader by right clicking and run as administrator (here is link to Loader) Windows 7 Loader.rar
Then just leave the loader on Default mode and click install... Now once you click install it will disappear don't worry it will take a minute or 2 then tell you to reboot.
Also if you wish you can tick the Advanced options and select your pc's make for serial and certificate's but it's not a necessity.
Now once you get the message telling you to Restart your computer simply click ok and let the system reboot.
And your all done your system should be fully Activated.
And able to pass validation on the microsoft site at Genuine Microsoft Software
Hope all this Helps you Good Luck !!
Tut by Bossa.
slmgr -rearm
Tut by Bossa.
Content blocked
While trying to retrieve the URL:
