make win7 genuine even with not genuine message on desktop !! without removing WAT
got the latest version of the loader, i'm on w7 ultimate, when i open the file its not allowing me to install it, the "install and uninstall" buttons at the bottom of the window remain grey and unaffected by cursor, any idea's chap's, please help.
thanks but still not having it, tried winrar,winzip,7zip,what am i doing wrong, saying file in unknown format or damaged can't open it, pleeeeeeeease help
yes no probs here is a screenshot plus a tut complete with step by step images tut in pdf & microsoft office word formats. which ever is best for you. hope this helps.
Muchas veces aplicamos varios patch para activar windows 7 y eso crea conflictos al momento de activar. Para eliminar todo rastro de patch usamos MBR Regenerator
Para usar:
ejecuta como administrador MRBRegenerator
Deja las opciones por defecto sin tocar nada y darle click en "Star Regeneration System"
Aparecera una advertencia emergente y le damos Aceptar
En la siguiente advertencia damos click a YES
Esperamos que termine el trabajo reiniciamos el equipo
y listo
al reiniciar ya podremos usar el windows loader para activar sin ningun problema... nuestro sistema limpio!!!
Perdon por no escribir en ingles
Saludos desde Colombia
To use:
MRBRegenerator run as administrator
Leave the default settings without touching anything and give click in "Star Regeneration System"
A warning popup will appear and give Accept
In the warning we click on YES
We hope that the work is done restart the computer
and ready
the restart and we can use the loader to activate windows without any problem ... our system clean!
Greetings from Colombia
Reason: Correction
You could of course not install the patches that cause the problem Then you only need to do it once, or get a copy of windows with the addons integrated into it after the date of the last attempt.
