make win7 genuine even with not genuine message on desktop !! without removing WAT
  • abnorm
    • Apr 2012
    doesnt work....crap!
    • smirnoff_rules
      • 8603
      #47
      new loader 2.12 here
      • sahilkh
        • Jul 2012
        AVG showing loader as Virus
        AVG showing loader as Virus..
        What to do??
        how to use the loader??
        • bolton20
          • Jul 2012
          #49
          Thank You
          Originally posted by bossa
          yes no probs here is a screenshot plus a tut complete with step by step images tut in pdf & microsoft office word formats. which ever is best for you. hope this helps.
          New to the site. Just quoting so I can have a look at the screenshots
          • bolton20
            • Jul 2012
            #50
            Problem at command prompt
            Bossa's Guide to Activate windows 7 with not genuine software message in corner.
            First of all open Command Prompt which is in Start Menu , All Programs , Accessories ... but you must run as administrator.
            Then simply type in this command:
            slmgr -rearm
            Within a few seconds you?ll normally see this dialog show up, saying that the command has completed successfully, at which point you?ll want to reboot.
            Now don't panic you will still get the not genuine message at start up but it shouldn't be in the corner
            of your desktop anymore.
            So Checking the system properties again shows that you now have so many days left to activate.
            Now run the Windows 7 Loader by right clicking and run as administrator (here is link to Loader) Windows 7 Loader.rar
            Then just leave the loader on Default mode and click install... Now once you click install it will disappear don't worry it will take a minute or 2 then tell you to reboot.
            Also if you wish you can tick the Advanced options and select your pc's make for serial and certificate's but it's not a necessity.
            Now once you get the message telling you to Restart your computer simply click ok and let the system reboot.
            And your all done your system should be fully Activated.
            And able to pass validation on the microsoft site at Genuine Microsoft Software
            Hope all this Helps you Good Luck !!
            Tut by Bossa.
            OK, when I open the command prompt as administrator and type slmgr -rearm I get the error message " 'slmgr' is not recogmized as an internal or external command, operable program or batch file. "
            What am I doing wrong here?
            • Hoppy01
              • May 2011
              • 374
              #51
              What to do??
              Its a false positive mate, by the nature of what it does most AV's recognize it as a hack tool in the signature description..
              Its actually a simple program created by a smart guy, it loads before Windows and acts as an emulator that tricks Windows into thinking its legit.
              Good AV,s list it as a minor threat but AVG is well known for going into pop up overdrive at the wrong things and then falling over and dying when it misses certain trojans listed as severe.
              A would disable AVG and then run the loader..
              "Windows - A thirty-two bit extension and GUI shell to a sixteen bit patch to an eight bit operating system originally coded for a four bit microprocessor and sold by a two-bit company that can't stand one bit of competition."
              • zorba anton
                • 98
                #52
                Make Windows 7 Genuine - Daz Loader
                *Find and 'Uninstall' KB971033 (don't 'delete' you must 'uninstall it)
                *Uninstall any and all 'Loaders'
                *Start 'Windows Update'
                *'Change Settings'
                *Uncheck 'Recommended Updates' (you'll need only important updates)
                *Reboot
                (You should not get 'Windows is not Genuine' warning.
                If you do, then check that KB971033 is NOT installed.)
                *Start Windows Update
                *Uncheck KB971033
                *Hide KB971033 (it will not show as an update again)
                *Install all important updates
                *Reboot
                You have 30 Days to Activate Windows 7
                Now you can install a Loader, and Reboot
                Windows Loader(x86/x64) by Daz + WAT Fix
                This is the loader application that's used by millions of people worldwide, well known for passing Microsoft's WAT (Windows Activation Technologies) and is arguably the safest Windows activation exploit ever created. The application itself injects a SLIC (System Licensed Internal Code) into your system before Windows boots; this is what fools Windows into thinking it's genuine.
                Windows Loader + WAT Fix (x86-x64) Main Features:
                Can be run as a standalone application
                Works well with all system languages
                Argument support for silent installs
                Can be used for pre-activation
                Application integrity checking
                It runs before Windows is launched
                Custom error handling
                It works with VMware, VirtualBox and Hyper-V
                It allows you to install custom OEM information
                Support for hidden partitions and complex setups
                Can work alongside Linux's GRUB or any other boot manager
                Works with TrueCrypt and many other types of hard drive encryption applications
                Add your own certificates and serials externally
                Offers certificate and serial installation only for users with an existing SLIC 2.1
                Automated system profiling (The application matches everything up for you)
                The rundown
                Compatible with Windows 7 SP1 and all system updates ***10004; check
                Will run on x86 and x64 systems ***10004; check
                No core system files get modified ***10004; check
                No extra processes are run so you have nothing eating at your RAM ***10004; check
                All key parts of the exploit are encrypted with a custom encryption ***10004; check
                The exploit runs before Windows so it's harder for Microsoft to prevent ***10004; check
                The exploit patches all necessary tables making activation look authentic ***10004; check
                The application will select the best profile for your system during installation ***10004; check
                Each and every user has a unique version of the exploit installed on his/her system ***10004; check
                Supported operating systems
                Windows 7 Ultimate
                Windows 7 Ultimate E
                Windows 7 Professional
                Windows 7 Professional E
                Windows 7 Home Premium
                Windows 7 Home Premium E
                Windows 7 Home Basic
                Windows 7 Starter
                Windows 7 Starter E
                Windows Vista Ultimate
                Windows Vista Business
                Windows Vista Business N
                Windows Vista Home Premium
                Windows Vista Home Basic
                Windows Vista Home Basic N
                Windows Vista Starter
                Windows Server 2008 Enterprise
                Windows Server 2008 Foundation
                Windows Server 2008 Standard
                Windows Small Business Server 2008
                Windows Storage Server 2008 Standard
                Windows Storage Server 2008 R2 Essentials
                Windows Server 2008 R2 Enterprise
                Windows Server 2008 R2 Foundation
                Windows Server 2008 R2 Standard
                Windows Small Business Server 2011 Standard
                Windows Small Business Server 2011 Essentials
                WAT Fix will:
                Uninstall RemoveWAT (or similar)
                Uninstall HAL7600
                Uninstall Chew7
                Uninstall uODIN
                Correct file permissions
                Correct important system files
                Correct services required for activation
                Correct VBS file associations
                Remove Microsoft entries from the HOSTS file
                Warning: Do not close WAT Fix while it's running.
                Note: You must be running build 7600 or greater for Windows 7 and Windows Server 2008 R2.
                Note: Not recommending using any of the Windows 7 E editions.
                Note: Windows 7 N editions will only be supported when OEM SLP serials leak.
                Note: Even if the icon is green someone might have found a way around the protection system so it's worth checking that the applications path is always the same as the location from which you launched the application.
                You should also check that the MD5 matches the MD5 found online.
                Language: English
                New Links : July 2012
                RUN AS ADMINISTRATOR
                Windows Loader 2.1.7 + WAT Remover 2.2.6 [7+Vista+Server] DAZ
                http://1337x.org/torrent/370604/Windows-Loader-2-1-7-WAT-Remover-2-2-6-7-Vista-Server-DAZ/
                http://www.nomaher.com/forum/index.php
                Windows Loader 2.1.7 By Daz
                http://1337x.org/torrent/371143/0/
                PM me if you have a problem with this or if my links go down.
                • vergel
                  • 162
                  #53
                  version 2.1.7
                  • Robert Tan
                    • Mar 2013
                    Hi I'm Newer here, I having the same issues with u all and wanna ask whether the instruction is works anot?
                    Besides, I have try to key in the command slmgr - rearm in the Command Prompt, but it do not reboot and it showed that it was not recognized
                    Pls help I have to settle this because I felt it unconvenience
                    • zorba anton
                      • 98
                      #55
                      Just download and run:
                      Follow the instructions.
                      There is No Virus or Trojan!
                      Tested and Working!
                      • Kyle925
                        • Aug 2013
                        • 49
                        #56
                        Make sure that if you use Windows Update dont install the update KB971033 as it is part of the WAT and can disable the activation.
                        Sorry zorba anton diden't see your post.
