can anyone reccomend computer repairer in gateshead/newcastle
  • footycard steve
    • 778
    i need to find a computer repairer in ryton/blaydon/newcastle can anyone reccomend a good honest repairer as i'm clueless,i live in ryton but i'm more familiar with newcastle.
  • the man
    • 1660
    whats up with it?
    • footycard steve
      • 778
      virus as in my other topic in this section.
      • the man
        • 1660
        hi mate , on some laptops theres a button to reset the system to new insall ie it will re set the lappy as it was the day you got it , theres to many posts there for me to look over on you other threed , if you can tell me what make and model lapptop you have? i maybe can help
        also is you can boot into safe mode , then back up all important files ,
        • Grizz
          • 1598
          @ The Man, Its a toshiba satellite l450-181.
          @FootycardSteve. First thing to do is look at the back of you Hitchhikers Guide to the Galaxy - DONT PANIC!!.
          I've downloaded the manual for you laptop and it says you have a recovery partition. if you decide to use this it will return your computer to the same as it was first day you turned it on. It will erase any files you have saved so if you have something important get a mate to try and get it off first. if you dont have anything important on it do the following...
          1:Turn off computer
          2: Hold 0 (ZERO) and turn on your computer.
          A menu will come up and all you have to do is take your time, read everything carefully and follow the instructions. it should take you back to a pristine virus free factory state. Good luck!
          • footycard steve
            • 778
            since i bought the laptop last july i have only downloaded avg,burnt some cds and loaded some photos ,i dont understand files etc so i never use them i have winrar installed on this computer and my boxloader software for my satellite box but nothing like that on my laptop. so if i turn it back to the as day i was bought the virus/malware will be gone?
            • barrowmanandrew
              • 3427
              if you follow grizz's advice m8 youur laptop will be good as new.
              no virus's, malware anything left on it.
              new as if you had bought it from the shop.
              • footycard steve
                • 778
                i've just held 0 whilst starting it up but it just gave me the spec i also had option for f2 or f12 boot i looked at the f2 section but could not find the info/section i need,i cant find the manual now as i've just moved everything around after buying a tv,i found the toshiba quickstart guide but on te section for restoring the pre-installed software it says refer to the manual and i also have the original toshiba product recovery disc.
                • footycard steve
                  • 778
                  i've just found the manual, i have found the system recovery options page. is this the section i need
                  SYSTEM RECOVERY OPTIONS
                  the system recovery options feature is installed on the hard disk when shipped from the factory.the system recovery options menu includes tools to repair start up problems,run diagnosics or restore the sytstem.
                  see WINDOWS HELP AND SUPPORT content for more info about START UP REPAIR.
                  the system recovery options can also be run manually to repair problems. the procedure is as follows.follow the instructions shown on the on screen menu.
                  1.turn off the computer
                  2.while holdiong the f8 key,turn on the computer
                  3. the ADVANCED BOOT OPTIONS menu will be displayed.use the arrow keys to selectREPAIR YOUR COMPUTER and press ENTER.
                  4.follow the on-screen instructions.
                  underneath it has grey info icon which says the windows 7 completepc backup featurecan be used on windiows 7professional and windows 7 ultimate.
                  is this the info i need?
                  • Grizz
                    • 1598
                    ok, stick in the recovery disk and restart. tell us what comes up, keep an eye on screen it may say push a certain button to boot from disc
                    • footycard steve
                      • 778
                      just added the section from the manual to my previous post.
                      • Grizz
                        • 1598
                        sorry mate missed it, follow their instructions and update us. ill wait here till you are up and running
                        • footycard steve
                          • 778
                          are you busy or can you stick with me ehile i try it and is it definately the right info i need.
                          • Grizz
                            • 1598
                            See above, i edited
                            • footycard steve
                              • 778
                              i have used f8 and i'm on a screen with lots of options the top one being repair your computer.
